Changed Break Pad; should I have greased the cylinder of the caliper?
Old Jun 19, 2011 | 12:16 PM
atriuum's Avatar
Is it a good idea to grease the outside of the cylinder shaped part of the caliper, before pressing it back into the caliper?
If yes, is silcone grease the right type for the job?
Also, how big a pain is it to change the rubber seal on that cylinder?
Old Jun 19, 2011 | 12:30 PM
maxed_out_99's Avatar
generally no. you shouldnt have to grease the piston. and you could replace the seal but 90% of the time if its worn cracked or broken the caliper is just replaced its easier and usually cost less.
now the slide pins on the other hand do need to bee cleaned with brake clean and regreased ive found the sinthetic based grease works the best
Old Jun 20, 2011 | 12:11 PM
cashoit's Avatar
i jus did brakes. I cleaned and greased sliding pins. Cleaned the bracket. Greased the backs of the pad. No issues or squeaking over here. Duralast golds ftw
Old Jun 20, 2011 | 12:45 PM
asand1's Avatar
I also grease the anti rattle clips in the torque member.
The piston does not get greased, just brake cleaner or compressed air.
Old Jun 20, 2011 | 12:57 PM
cashoit's Avatar
Asand,
When u clean the caliper with brake cleaner..shd i be gentle or jus hammer it with spray and wire brush it afterwards?
Old Jun 20, 2011 | 01:15 PM
asand1's Avatar
I just spray the piston/dustboot liberally with cleaner and then air. It will be easier before you compress the pitson. Be careful with compressed air, you could damage the boot. Compressed air + brake dust "could" cause cancer btw. Last time I did brakes all I used was air and rags due to budget, and did just fine. A wire brush is fine for metal parts bit stay away from rubber. You could use a toothbrush.
Old Jun 20, 2011 | 01:17 PM
asand1's Avatar
I don't. Worry about the caliper body, just the sliding parts.
RWCreative
Sep 21, 2015 11:01 AM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
SusieQQ
Sep 9, 2015 12:14 PM
beerman1378
Sep 8, 2015 02:19 PM
