Are SE springs firmer than GXE or GLE?
Old Jun 24, 2011 | 08:04 PM
Nopike's Avatar
I have to replace my front springs and my understanding is that the SE has firmer springs then the GLE or GXE. A lot of places seem to sell the same springs for all the models. Short of buying them from Nissan how can I make sure I get the right springs. Do they look or measure different?
I really want to make sure I keep my firm ride because I would not have purchased a GLE or GXE with the softer ride.
http://forums.maxima.org/4th-generat...eleration.html
Old Jun 24, 2011 | 09:46 PM
95Maxed's Avatar
Have you thought about purchasing lowering springs?
Old Jun 24, 2011 | 09:54 PM
Nopike's Avatar
I've had this car for 13 years and it's still in good shape but starting to rust and get kind of beat up. I'll replace it within a couple of years so I'm just trying to keep it going.
Don't really want to put any more money into it than I have to. I like a firm ride but if I get lowering springs then I have to do the front and rear? And also install new struts?
I'm trying to keep this job simple and cheap. I appreciate the suggestion anyway.
Old Jun 24, 2011 | 10:07 PM
gto400no1's Avatar
Chances are if you need to replace the springs you probably are due for new struts anyway.
Old Jun 24, 2011 | 10:15 PM
Trini Boom's Avatar
Hold on now, I read or was told by someone that the springs do not go bad unless if they break. Did I hear wrong? Why are you replacing yours OP?
Old Jun 25, 2011 | 03:24 AM
Br0nz's Avatar
i just did monroe quick struts, i could have waited as my struts were not bad at all :/
however i do feel a difference in some areas i did not think i would. for instance:
going around a corner at a grade under acceleration, before i would get wheel spin now the car feels more planted and is able to get more grip.
no one seems to offer different springs for SE which i what i have but in a 10-15 year old car any brand new sping is going to be firmer than what you have now!
Old Jun 25, 2011 | 03:27 AM
Br0nz's Avatar
they CAN be used for the life of the car. however i have put quick stuts in four different cars now. they DO feel firmer (some more then others i learned my max wasnt that bad)
changing the springs also helps your struts to do less work and they will last longer.
Old Jun 25, 2011 | 04:20 AM
Nopike's Avatar
My spring is broken, due to rust. Story is in the link below. That's why I need to change it. The struts were replaced 30-40K miles ago so I don't think they need to be replaced again.
The springs appear to have color codes hand painted to identify them. When I bought my Maxima new I drove the SE and the other models. The ride of the other models was not nearly as stiff all around as the SE's. Maybe it's due to something else but I have to think the springs had something to do with it.
Old Jun 25, 2011 | 10:20 AM
iDuty's Avatar
The damping properties of the struts also make a big difference in the stiffness of the ride. This partly explains why putting on a new quick strut assembly makes the ride stiffer - the new strut cartridge itself is resisting motion more than the old strut.
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
