still no power
Old Jun 26, 2011 | 03:30 PM
NHMAX603's Avatar
still no power
iver finaly given up i have no power to one entire door the rear drivers side i think im just gonna pay team nissan to fix it or leave it and sa sorry to the next poor bastard to sit in the rear with my car parts lol
Old Jun 26, 2011 | 04:00 PM
tigersharkdude's Avatar
pull your window switch and make sure its got a good solid connection via the harness plug
Old Jun 26, 2011 | 04:50 PM
NHMAX603's Avatar
ive basicly rebuilt my entire door its basicly come down to now power getting to the door but all the others are getting power F.M.L
Old Jun 26, 2011 | 09:25 PM
Trini Boom's Avatar
No kind of power going to the switch or window regulator can only mean there's a problem with the harness. There is no relay or fuse that controls one door. I would check where the harness joins to make sure that there is continuity on both sides of the plugs.
Old Jun 27, 2011 | 06:35 AM
cashoit's Avatar
u prolly jus need to replace the relay. is power getting to the door?
Old Jun 27, 2011 | 09:18 AM
NHMAX603's Avatar
my power locks don't even work
Old Jun 27, 2011 | 10:14 AM
max ride 41's Avatar
there you go dude, you answered your own question. locks and window dont work then the wire is probably cut or bent in a way to prevent power to the door. id double check the wiring to the door. and clean the connections in drivers side door as well so they're solid.
Old Jun 27, 2011 | 02:00 PM
bobflood's Avatar
Different wires bring "power" into the door for lock and window - more likely a grounding issue. Check inside the rubber tube that covers the wire bundle that goes into the door - bet you find one or more broken wires.
Old Jun 27, 2011 | 04:57 PM
NHMAX603's Avatar
i completely rewired the door with a new harness all the way to the pillar im guessing i should chase them the rest of the way into the driverside door and keep going iver rebuilt drivers side too and have replaced master switch swaped switches in the rear and back again next ill jump up and down 6 times clap twice spin 32 times and mabey it will work
Old Jun 27, 2011 | 06:33 PM
lol ok spongebob only if you do it around the car
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
