Rotors milled??
Old Jun 28, 2011 | 10:10 PM
hitm4n666's Avatar
Rotors milled??
Hello .org I've been slowly buying things for my 300zx caliper upgrade in my 95 maxima. I've been reading and other people were saying they had too mill down the rotors 4-8 mm.... Exactly what r they talkn about I don't understand
Old Jun 29, 2011 | 03:58 AM
ajm8127's Avatar
Search here for your answer.
Old Jun 29, 2011 | 05:49 AM
cashoit's Avatar
ppl still resurface rotors???
Old Jun 29, 2011 | 06:21 PM
Trini Boom's Avatar
Same thing I was thinking? Does it cost $20??
Old Jun 29, 2011 | 06:29 PM
Brandon8965's Avatar
but the rotor is too tall to use that set up with the stock brackets so you have to mill the outter diameter to fit
Old Jun 30, 2011 | 06:43 AM
Flava_24/7's Avatar
Boosted Panda
When mounting the Z32 caliper onto the A32's caliper mounts it will cause the rotor to hit the inside of the Z32 caliper since its much larger then the A32 caliper. So you have to mill off some of the outer diameter.
Also, if your using the A32's bolts, use a coupler of washers or they will hit the rotor. You will also need to grind down some of the LCA cause they will also hit the rotor since its much thicker then the A32 rotor.
Old Jul 1, 2011 | 08:41 PM
hitm4n666's Avatar
thx so much for your answer thats exactly wat i figured!!!
........sum people just cant seem to atleast act half decent jezz
Old Jul 2, 2011 | 09:16 AM
ajm8127's Avatar
You asked an advanced question about a retrofit BBK so I figured I would refer you to the sub forum specifically for this type of question, which has been asked and answered before.
Old Jul 2, 2011 | 09:26 AM
Fatboy98maxima's Avatar
rotors are not that expensive i would just buy new ones
Old Jul 3, 2011 | 09:47 AM
wirelessdude04's Avatar
Well it depends. If there 2 peice rotors yea i would try and resurface them cause there expensive.
Sorry not everyone is a baller like you to buy new rotors
Old Jul 3, 2011 | 11:02 AM
oem rotors aren't that expensive but q45 rotors and every other setup for a BBK would be extremely costly to "just buy new ones"
Old Jul 3, 2011 | 11:10 AM
if u cant spend a little bit of money on the most important component on the car between life and death then u shouldent own a car
Old Jul 3, 2011 | 11:18 AM
initially yea spend that money... but if you mess up then it costs alot to fix is all i was saying.. never said that you shouldn't buy em chill
Old Jul 3, 2011 | 12:40 PM
Flava_24/7's Avatar
Boosted Panda
But doesnt make sense to just throw away money if you dont have to.
Money saved can be applied else where.
Ahigh end set of name brand rotors really areant "cheap", and AutoZone rotors or the likes of arent considered high end rotors.
But yes, they would be cheap enough to replace at every pad change.
Old Jul 3, 2011 | 01:50 PM
++ 1 i agree
Old Jul 3, 2011 | 01:53 PM
there is nothing to chill about this a forum to discuss things
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
