please help asap. my car wont start and im about 500 miles from home
Old Jun 29, 2011 | 08:56 PM
K31J1m0N's Avatar
i have a 97 manual maxima and my ignition switch will not power anything for some reason, not the accesories, radio, the starter or anything. doesnt even click. luckily i had a new one in my car and hooked that up but still nothing. checked every individual fuse in the car and under the hood. am i missing something or didnt check something?everything in the car works except the thing that turn on when the ignition switch is turned to on.anyone please help me otherwise im stranded or hit me up 6108008599
Old Jun 29, 2011 | 08:59 PM
colombianmaxima's Avatar
explain how this happened , did it hanppen while u were driving
if u were in ny i would meet u up
Old Jun 29, 2011 | 09:01 PM
K31J1m0N's Avatar
went in to get a drink and tried to start it and this happened. dont kno,if so, if a relay would affect this.any relay controls the igniton switch?
Old Jun 29, 2011 | 09:15 PM
try tappiinng the starter , check for any water/corrsion by the fuses/relays on hood,
yuor battery is good ? headlights work at all?
Old Jun 29, 2011 | 09:18 PM
K31J1m0N's Avatar
everything in the car works. the ignition switch is just not working. no acc, no on postion, no start.
Old Jun 29, 2011 | 09:23 PM
u can turn the key though? or it stays locked the ignition
Old Jun 29, 2011 | 09:24 PM
K31J1m0N's Avatar
yes im able to turn the key
Old Jun 29, 2011 | 09:25 PM
wait do you have like a rs or an alarm , if so then it most likerly that bc i had this same problem with my 99 and it was the way the alarm was installed
im going to check my max right now
Old Jun 29, 2011 | 09:32 PM
K31J1m0N's Avatar
i dont use that bull****.lol
Roosky's Avatar
does the key feel weird when you turn it? i've had the metal part that actually turns the switch break in half on me before
Old Jun 29, 2011 | 09:37 PM
K31J1m0N's Avatar
i use a flat head directly to the ignition switch cuz i dont have a key assembly since it broke
Old Jun 29, 2011 | 09:43 PM
neocry's Avatar
Could it be possible that you are a victim of the infamous 99 immobilizer?
Edit: Never mind, I miss read that you have a 97. Sorry.
Old Jun 29, 2011 | 09:44 PM
MAXEnvasion's Avatar
is it a 99?
is the red security light on?
it could be immobilzed thats what happen to me
Old Jun 29, 2011 | 09:52 PM
K31J1m0N's Avatar
Originally Posted by MAXEnvasion
is it a 99?
its aa 97 and for future ref, even if the immobilizer is engadged, the on position can be aquired, just wont get spark to start the car
neocry's Avatar
You always have the option of hitting the starter or jumping the car (the old fashion way) by pushing it and starting it in 2nd gear?
Old Jun 29, 2011 | 10:01 PM
Roosky's Avatar
he cant get the switch to work ( get it to "on" position) So ECU doesnt get the power, so starting it in 2nd gear or hitting the starter wont do anything.
Is your spare switch a known good switch?
Old Jun 29, 2011 | 10:06 PM
neocry's Avatar
Last resort for me would be taking advise from this video (screw driver in the ignition bid).
http://www.youtube.com/user/boredmde...26/4ykT9uCJXSY
Old Jun 29, 2011 | 10:08 PM
K31J1m0N's Avatar
brand new oem
Old Jun 29, 2011 | 10:10 PM
vw3819's Avatar
Is it possible that the battery is strong enough to power lights, etc., but not enough to engage the ignition?
Old Jun 29, 2011 | 10:11 PM
K31J1m0N's Avatar
not possible
Old Jun 29, 2011 | 10:12 PM
i feel like its ur battery bc if u tried everything , and things still somewehat turn on seems like maybe battery low , bc i just pulled some fuses and then i put in a almost dead babtery and it almost had the same symtopms as urs
Old Jun 29, 2011 | 10:13 PM
but mines a 99 with electrical problem
Old Jun 29, 2011 | 10:27 PM
neocry's Avatar
Have you actually tried to jump the car (with jumper cables)? If not, just try it.
Old Jun 29, 2011 | 10:43 PM
K31J1m0N's Avatar
Y would i jump the car if it wont.engage into the on position. Itll just shut off.
Old Jun 29, 2011 | 10:50 PM
neocry's Avatar
Dude, I'm just trying to rule out all the possibilities that's all.
Starter: no
Ignition: no
Immobilizer/alarm: no
Jump start 2nd gear: no
Battery: you say hell no.
Old Jun 29, 2011 | 10:52 PM
Snypa's Avatar
Starter: no
Ignition: no
I agree. Try and rule stuff out. So far, it sounds battery related, then sounds starter related, then ignition related. Try jumping it if you can. Since you said there is no power at all, lets see if someone elses battery will allow lights and radio to atleast come on.
Old Jun 29, 2011 | 10:56 PM
Snypa's Avatar
It has to be your ignition switch or wiring from the switch to the battery that's gone.!
Old Jun 29, 2011 | 11:00 PM
Nopike's Avatar
Can you hear the ignition relay or acc relay click on when you turn the key to these positions? Those relays are just to the left of the fuse box.
Old Jun 29, 2011 | 11:02 PM
Nopike's Avatar
I'm not sure those relays are the same try swapping them out if they are.
Old Jun 29, 2011 | 11:22 PM
ef9's Avatar
ef9
If you have an auto trans, is it in Park? Wiggle the battery terminals and see if they are on the battery posts (really tight).
Old Jun 29, 2011 | 11:29 PM
max ride 41's Avatar
wow, you people sure lke to repeat urselfs sometimes. you sure you put the switch in right?? all wires are tight and connected??? you might want to check that.
Old Jun 30, 2011 | 12:29 AM
K31J1m0N's Avatar
figured it out. the ignition fuse blew internally. something told me to completly rip that ***** apart and it was mangled. the metal strep was fine to the eye and tested fine but interanlly was ****ed. thanks for all who tried to help and those who just throw answers out there without reading . :-) and special thanks to the dude who called me to make sure i was straight
Old Jun 30, 2011 | 10:18 AM
Snypa's Avatar
Kudos !^
Lakersallday24
Jun 16, 2019 01:35 AM
Maxboy23
Aug 11, 2015 11:59 AM
mrgooch
Aug 9, 2015 11:00 AM
niZ
Aug 7, 2015 10:18 PM
