IRRITATING Idler Tensioner Pulley Assembly **NEED HELP**
Old Jul 11, 2011 | 09:14 PM
mpvibes's Avatar
What is the proper order for the idler tensioner assembly? I've researched on the org and I'm not able to find a definite assembly order breakdown of this. Here is what I found and tell me if this is the correct assembly order (this was from a 93 maxima, scroll down to post #4) : http://forums.maxima.org/3rd-generat...lley-help.html
And
Courtesy Parts Link: This one confuses me a bit because there are more washers and parts here than in the above link.
http://www.courtesyparts.com/maxima-...1822_1844.html
I need to know the accurate # of parts for the assembly or any real pics! Thx
Old Jul 11, 2011 | 09:22 PM
JNCoRacer's Avatar
Just the tip.
The Courtesy description has it in order.
Old Jul 11, 2011 | 09:23 PM
mista0406's Avatar
You should look a little better here you go.....
http://forums.maxima.org/4th-generat...-assembly.html
Old Jul 11, 2011 | 09:42 PM
mpvibes's Avatar
Thx but, I did see this thread. He is missing the thick spacer in that pic. I was trying to find it already assembled in order with pics.
Old Jul 11, 2011 | 09:45 PM
mpvibes's Avatar
Also, is the 93 maxima tensioner assembly order the same as the link I posted up?
Old Jul 11, 2011 | 09:47 PM
mpvibes's Avatar
I'm also confused on which way the pulley wheel faces.
Old Jul 11, 2011 | 11:36 PM
mista0406's Avatar
the thick spacer is in between the pulley wheel (probably in the picture its already on the wheel) and the bolt adjuster. the courtesy parts page is pretty self explanatory
Old Jul 11, 2011 | 11:42 PM
mista0406's Avatar
its more like this... theres 2 different ones
http://www.courtesyparts.com/maxima-...1648_1670.html
i thought you were looking for a 4th gen?????
Old Jul 12, 2011 | 08:27 AM
mpvibes's Avatar
Ok, thx. I'm gonna be working on it today and see how it works out. The problem I'm having is the pulley rubbing and spinning against the tensioner adjuster, which caused it to cut through.
Old Jul 12, 2011 | 10:17 AM
SandyMax96's Avatar
That should be fine. Mine had been cut through some of the way and it still works. I might be missing the spacer but, again, it works. The spacer goes between the pulley and the long tensioner. And the pulley should be facing just like it does in the previous photos. Just remember that the open ended more cut out circular side of the pulley goes towards the engine and the smaller opening goes out toward the fender. Hope that helps.
Old Jul 12, 2011 | 10:45 AM
mpvibes's Avatar
Ok, thx. Well, after assembling the tensioner and testing it on the car, it turned out my pulley bearing was bad. Everything was fine until I revved the engine and the bearing in the pulley was coming out Looks like I will be ordering the entire tensioner assembly w/ pulley from Courtesy Nissan, I think that's the best route instead of buying it in pieces.
Old Jul 12, 2011 | 01:09 PM
SandyMax96's Avatar
Dude, the pulley is only about $20 from AutoZone... And the tensioner should only be replaced if it's bent or warped. That's what I did on my friends max when we over-tightened the tensioner and it snapped. The tensioner assembly, $7 from a junkyard, and the pulley was only, like I said, about $20, with a year or 2 of warranty. Don't go spending on overpriced items from courtesy that would take days to ship when you could just go into your autozone and get it done that same day. If it's the bearing, just buy the pulley. If you want to make sure it's the correct pulley, bring it with you to when you buy it from them. That's just my .02
Here's the link for the pulley from autozone. http://www.autozone.com:80/autozone/...er=445425_0_0_
it's $22.99. I was just rounding an estimate. Hope it helps.
Old Jul 12, 2011 | 04:06 PM
mpvibes's Avatar
Thx for your help and info. I hear what your saying but, I've been having some on and off problems with this ENTIRE tensioner pulley assembly. I changed the pulley about a year 1/2 ago. I broke the tensioner adjuster earlier this year and bought one from the dealer. I'm tired of buying bits and pieces here and there. Also, I think somewhere along the line I screwed up the assembly (missing parts). Once I get the entire Nissan tensioner assembly, it will solve my problem.
Old Jul 12, 2011 | 09:48 PM
mpvibes's Avatar
Does anyone know why the pulley tensioner goes towards the tensioner adjuster and rubs on it, causing sparks to fly? This happens when the car is on and when you rev the engine. It's like the more you rev it the more the tensioner pulley draws closer to the tensioner adjuster and also the belt kind of moves off of the pulley too.
Old Jul 13, 2011 | 12:59 PM
mpvibes's Avatar
Anyone????
Old Jul 13, 2011 | 01:04 PM
cashoit's Avatar
this is over my head vibes man.
I wd have jus bought a new tensioner and had my mech install
Old Jul 13, 2011 | 01:17 PM
mpvibes's Avatar
Ok, thx cashoit. Hopefully when I get my brand new tensioner assembly this won't be a problem. I think my idler pulley wheel and bearing is the cause of this.
Old Jul 13, 2011 | 02:52 PM
ThurzNite's Avatar
I don't remember. I have a thread asking the same question. Being impatient, I tried both ways. 1 way rubs, the other doesn't. Problem solved.
My pulley exploded on me while on the highway 300 miles from home... Luckily I knew it was going to happen cuz it was making noise and like the poster above said, I bought a spare pulley and just kept it in the trunk plus tools necessary.
Also as noted above, if you're not sure, buy the whole assembly, then sell the old one on this forum.
Dr J
Old Jul 14, 2011 | 12:13 PM
mpvibes's Avatar
Dr J
Yeah, that's what I'm gonna do. I'm gonna just buy the whole assembly. Thx for the input.
Old Jul 23, 2011 | 01:39 PM
mpvibes's Avatar
Ok, I finally got my brand new Tensioner pulley assembly and got everything fixed! I bought it from an Infiniti dealer in New Jersey on ebay! It was $60 shipped!
Old Jul 23, 2011 | 02:14 PM
Blakfreestyle's Avatar
Yeah sometimes you just have to cough up the money. The tensioner is over 10 years old. When I changed mine it wouldn't get tight enough so I bought a new one.
Old Jul 23, 2011 | 04:36 PM
mpvibes's Avatar
Yeah, that's true...
Old Sep 16, 2015 | 04:22 AM
sprater23's Avatar
my pulley is still hitting the adjuster rod
Pulley is still hitting adjuster rod even though i have 1/4 spacer between pulley and the rod
Old Feb 14, 2025 | 01:43 PM
Sparky50023's Avatar
Removing Idler belt tensioner 98 Maxima GXE 3.0
Is there a specific order to get the Idler tensioner off the block to replace the whole thing? I am having a rough time doing so. I looked at the OEM service manual I have on disk, but it is very limited on info. and doesn't tell the order you are to do to remove the tensioner. HELP!!!!!!! please.
Old Feb 16, 2025 | 12:32 AM
Neither of your links open up to a page that works.
Old Feb 17, 2025 | 09:13 AM
slvr2KSE5's Avatar
probably because this is a 10 year old thread.
remove nut on pulley, remove pulley, remove bolts holding bracket to engine.
02PearlSE
Feb 1, 2016 12:37 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
