Automatic Shifter indicator light/ light around cig lighter
Old Jul 14, 2011 | 06:40 AM
caseymaxima's Avatar
Hi everyone,
The auto shifter indicator light is currently out as well as the light around the cig lighter in my 96 Maxima. The car was the shop for E-brake repair, and they had to remove the center console to fix it. Well now I have no lights there as indicated above.
Prior to the repair of the E-brake, at times the shifter light would be out and all I would need to do would be to tap the indicator light area gently, and it would light up. I assume the bulb is ok,so it "should" be something related to the connection. Does anyone have an idea where those two light are connected? How do I go about checking them? Is there a seperate fuse in the box for those two lights?
Thanks,
Zack
Old Jul 14, 2011 | 07:10 AM
T-Mon3y's Avatar
Don't know off the top of my head, but if they broke it they fix it.
Old Jul 14, 2011 | 07:58 AM
Well to be fair to the shop, it was having "some" issues before. As I said at times it would be out, and I would tap the shifter light area, and it would work.....Now when you tap ythe shifter light area it does not light up.
Thanks,
Zack
Old Jul 14, 2011 | 08:52 AM
Roosky's Avatar
is there a light around the cig lighter? pretty sure my 99 doesnt have one. as for the shifter light, pop the plastic cover off and see whats going on in there, probably just loose connection
Old Jul 21, 2011 | 08:15 PM
Well I popped the black plastic trim off, but from there where do I go? I have no clue how to open up the shift indicator unit? I could not find any wires, or how to open up the unit. What am I missing? What kind of bulb is in there?
It is annoying driving the car at night with no light down there...
Thanks,
Zack
Old Jul 21, 2011 | 10:20 PM
danmack34's Avatar
Pop your shifter trim up and check if they forgot to plug some plugs in. There is two plugs I know of down there on my 5speed
Old Jul 22, 2011 | 03:25 AM
On my auto, I could not seem to locate any wires, I assume they are under the shifter unit. Is there a bulb to burn out in there? I checked my fuses, and they are fine.
PS: Everyone else jas a green light around your cig lighter correct?
Zack
Old Jul 22, 2011 | 05:26 AM
Trini Boom's Avatar
I have not heard or seen a light around the cig lighter in my 95 either. Your bulb probably needs to be replaced.
trasmadean
Jan 20, 2018 05:05 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
MaxLife17
Sep 8, 2015 02:36 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
