Noise coming out of the shifter box
Old Dec 27, 2001 | 06:26 PM
EuroMaxima99SE's Avatar
I don't know where exactly its coming from, sounds like a piece of plastic is rubbing on something in 1st, 2nd, and sometimes in 3rd gear, when you let go of the gas, but not in neutral. What can it be and how much would it cost me? It has gotten worse starting yesterday, before it was just making this noise only on sharp turns in 1st or 2nd gear...Thanks for any replies!!!
Old Dec 28, 2001 | 03:23 AM
Mishmosh's Avatar
Re: Noise coming out of the shifter box
It is doubtful that your shifter is causing the problem. However, right below that is a heatshield, and also the CAT and end of the Y-pipe. It is fairly common for the bracket holding up the Y-pipe to hit against the metal above it, and also for the heatshield to be loose. The exhaust vibrates under throttle but also sways during cornering. My advice would be to push and prod things down there while the car is cold (so you don't burn yourself on a hot exhaust) and see if you can hear the sound and its origin. Some have bent the metal above the Y-pipe bracket...
Old Dec 28, 2001 | 03:00 PM
Re: Re: Noise coming out of the shifter box
Thanks for the advise, it doesn't sound like a metal rubbing but like a plastic...anyway, I'll check it out. Thanks.
Old Dec 28, 2001 | 03:16 PM
maxedout95's Avatar
I had the same problem and today I went to get my oil changed and when the mechanic lifted the car up I noticed that my heatshield over the catalytic converter was loose and the heatshield by the y-pipe was all ripped up. So after I tighted the bolts up the rattling stopped when I shifted at lower gears but I still hear some quiet knocking from underneath when I go faster so I guess I have to get a new heatshield for the y-pipe and see if that helps.
Hondarydr
Dec 30, 2024 06:15 PM
maxima-junky
Oct 21, 2015 05:17 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxima-junky
Aug 13, 2015 09:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
