quick strut installation
Old Aug 4, 2011 | 09:45 PM
Perseus's Avatar
has anyone installed quick struts before? all the reviews briefly mention that the 3 studs need to be rotated but i have no idea how to do it. my studs/the top plate seem to match up with my old struts but the studs won't line up with the wheel well/under the hood
Old Aug 4, 2011 | 09:47 PM
chrome91's Avatar
as in the full assembly with the strut/spring all read to go? all you have to do is remove the old strut, put in the quickslut so the bottom part/3 studs on the top match up the same way as the old one did and bolt em down
Old Aug 4, 2011 | 10:02 PM
Perseus's Avatar
have you done it before? i have it in my garage right now and it doesn't line up
the reviews on it say something like "The top of the strut setup will need to be rotated to line up correctly with the bolt holes"
Old Aug 5, 2011 | 07:07 AM
njmaxseltd's Avatar
The upper mount rotates, it's on a bearing. Use some force and spin it, it will turn and align correctly to the 3 holes.
Old Aug 5, 2011 | 08:17 AM
bobflood's Avatar
+1. Rotate the upper plate so the bolts line up with the holes.
Old Aug 5, 2011 | 09:21 AM
Jliner's Avatar
if its the monroe struts they even have an arrow on that top plate i believe it points out when its aligned properly.
Old Aug 5, 2011 | 02:19 PM
Perseus's Avatar
yea it's the monroes. what's the safest way to rotate the plate? don't want to damage the threads
nvm threads were strong enough. used the back of a crescent wrench and my foot
Old Aug 6, 2011 | 01:50 PM
Perseus's Avatar
when i go in for an alignment is it gonna be a big deal that i put these in? i know the top plates weren't identical to my previous ones so they don't line up with the axle exactly how they used to
Old Aug 6, 2011 | 05:30 PM
Br0nz's Avatar
No the old ones were just far out of spec after all these years. I suggest looking for a coupon for firestone lifetime alignments for $120 I think.
Maxima_Joe
Nov 25, 2015 08:19 AM
kingw323
20
Oct 21, 2015 08:36 AM
Johnny9595
Sep 3, 2015 05:18 AM
soloist3
29
Sep 1, 2015 03:47 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
