squeeking noise in heating vents
Old Dec 28, 2001 | 08:09 AM
PolishMax's Avatar
Anyone know how to fix this?
Old Dec 28, 2001 | 08:29 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: squeeking noise in heating vents
squeaking or more of a howling???
what vents? the front vents... top vents???
happening at all speeds??
what about when the fan is turned on... multiple speeds??
just trying to get more info to help
Old Dec 28, 2001 | 08:36 AM
PolishMax's Avatar
Its a squeeking. Its most noticable at 1-3 speed and it goes away on 4. It seems to be coming mostly from the top vents. If it helps for any reason its a 97.
Thanks in advance.
Old Dec 28, 2001 | 08:48 AM
Bags's Avatar
Thanks in advance.
does the noise change or go away when you change vents?
like it you move it to the floor vents? or is it still there?
is it just the heater or does the a/c do it as well?
Old Dec 28, 2001 | 09:02 AM
PolishMax's Avatar
It seems to be the same on all of them...havnt tried the A/C...kind of cold so i didnt think about it....
Old Dec 28, 2001 | 11:23 AM
jdmmax's Avatar
hey my car does that to sounds like there is a cricket in the vents. its like one countinuous wistle when a/c is on 3-4. i don't know what it is. and now there is a vibrating noise when i use the heater. sounds like a pagers or phone on vibrate mode. WTF!!!!! man
it drives me crazy!!!!!!
Old Dec 28, 2001 | 12:27 PM
Eric L.'s Avatar
Check the blower motor for obstructions. A couple years back, I had a squeaking noise when I turned the fan on 1 or 2. Dealer replaced the unit under warranty, stating "defective blower unit."
Old Dec 28, 2001 | 12:32 PM
iansw's Avatar
I think i know what it is.
The vents for the top "defrost" vents (the ones that defrost the die windows, not the one at the windshield) are made of hard plastic, and rub against the inside of the dash, making an annoying "squeak"
What I did was take a piece of cardboard and put it wedged inbetween the A-Frame and the dash. That moved the dash JUST enough to stop the rubbing.
If you wedge the cardboard in there well, it won't be visible.
IanS
Old Dec 28, 2001 | 02:26 PM
PolishMax's Avatar
Thanks iansw. I'll give it a try.
Old Jan 2, 2002 | 01:14 PM
PolishMax's Avatar
Well that didn't work any more ideas???
Old Jan 2, 2002 | 06:18 PM
BippuBenji's Avatar
I wish I could help, but I'm having a similar problem as well. I hear a knocking/squeeking sound coming from the center vents whenever I take turns or go over little bumps. It's quiet when I drive straight, but just the slightest turn and it starts up. Does anyone know how to fix this? Someone please help. Thanks.
Old Jan 4, 2002 | 11:06 AM
PolishMax's Avatar
bump....Any ideas???
Old Jan 4, 2002 | 04:47 PM
kvzeyde's Avatar
noise with blower for heater/ac
My fan was making a noise some of the time but not always. I pulled the blower and squirrel cage out (remove the glove box and go from there) My squirrel cage had the pieces from a lid from a Mcdonald's coke cup! Once I cleaned it out, the noise was gone. Don't know if you have some debris in yours but you might check.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
