One headlight goes dark; High Beam Ind comes on ???
Old Aug 8, 2011 | 04:48 PM
BobMax's Avatar
on a 99' SE...
Having a problem where one headlight will go out. When it does, the high beam indicator (on dash) lights up. No amount of switching the switch seems to fix eithe rproblem, but within a few minutes it typically corrects itself - headlight comes back on, high beam indicator goes out.
Is there a relay that typically goes bad in these? Or the switch? I could use some pointers to common ailments.
Thanks,
Old Aug 8, 2011 | 04:55 PM
T-Mon3y's Avatar
Try pushing the connector all the way in for the headlight that keeps "going out".
The high beam indicator goes "on" to tell you that one of ur headlights is out.
Old Aug 8, 2011 | 05:17 PM
asand1's Avatar
You've got an element in one headlight that is burned out, but still occasionally makes contact and illuminates. Replace both headlights and be done.
Old Aug 8, 2011 | 11:29 PM
BobMax's Avatar
Thnaks boys... I didn't know of the "headlight out" indicator. I'll try cleaning the connector on the bad one and replace the bulb if that doesn't do it.
Bob
Old Aug 9, 2011 | 05:48 AM
Br0nz's Avatar
take a look at the harness ill be willing to bet the ground contact on the bulb socket is a little burnt and now so is the headlight contact(s). if so you may need to replace the socket, i cut mine and soldered in a new one.
Old Aug 9, 2011 | 11:43 PM
schmellyfart's Avatar
Exactly what happened to mine, I soldered in a new connector and all is well.
Old Aug 12, 2011 | 04:05 AM
Br0nz's Avatar
so what happened bob-o?
Old Sep 7, 2011 | 01:02 PM
BobMax's Avatar
Finally got out there last week to repair it...
Turns out the connector was seriously degraded. One pole of the connector was corroded and/or burned. I imagine it corroded first, then the resistance caused it to start burning off. I replaced the connector and it's back in proper operation.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
