backfire and IACV Ticking Videos. How do i alleviate these problems
Old Aug 8, 2011 | 08:19 PM
maxxxdout's Avatar
This is a video of a ticking noise coming from my IACV..
http://youtu.be/2kpaOggUxL0
This is the problem that im experiencing you can hear everything and see what my RPMS are at in this Video
http://youtu.be/KTiYPyzLu1Y
Old Aug 8, 2011 | 08:27 PM
huzzaj's Avatar
have u checked ur spark plugs and coils mine was doing this a while ago and i changed one coil and it fixed it
Old Aug 8, 2011 | 08:29 PM
huzzaj's Avatar
or could be a clogged air filter is that aftermarket? right
Old Aug 8, 2011 | 10:13 PM
maxxxdout's Avatar
i changed the plugs today... As far as the coils go. i replaced them in february. But they were some used ones..... The air filter was just put in about 2 months ago. Hence my confusion. Also i checked the coils they dont seem to be the problem. Also as you can see, i have no CEL
Old Aug 8, 2011 | 10:24 PM
Shift_A32B's Avatar
Maybe you have a bomb in there somewhere...
Old Aug 9, 2011 | 12:15 AM
MaximaSpd85's Avatar
Was there anything specific that you did just before the backfiring started happening? The times ive had backfiring from the intake was from vacuum leaks.
Old Aug 9, 2011 | 07:27 AM
njmaxseltd's Avatar
That sounds horrible.
Also looks like you have no power as that's a rev with no load on it, the RPM's should shoot right up. Big time lag there.
The back fire points to an ignition issue, I would suspect coils are at fault.
Check the signal from the MAF sensor, it may also be lagging.
My .02 is the intake isn't doing you any good either in the throttle response area.
Old Aug 9, 2011 | 08:00 AM
cashoit's Avatar
since u not gettin no codes check for vacuum leaks. Im leaning towards either MAF or TPS or vacuum leak.
Old Aug 9, 2011 | 08:17 AM
maxxxdout's Avatar
before this crap started my throttle response was fine.... my car was hauling *** with no problem, making mincemeat of other cars... as far as the backfire goes... i have no idea... i tried checking for any leaks yesterday but it was beginning to get late so i called it a day... Im thinkin tps myself also because i just swapped the Maf in there although it was a used one, but the car was running just fine
Old Aug 9, 2011 | 12:25 PM
Ahh so u just installed that maf? And this is what became of it? Come to think of it i had a customer with the same problem, we cleaned his maf with the cleaner and it got a lot better. Maybe Try cleaning it...
Old Aug 9, 2011 | 12:44 PM
maxxxdout's Avatar
ill give it a shot... thanks
Old Aug 9, 2011 | 12:46 PM
Bronzie2K's Avatar
Just curious, did the ticking and the rev issues appear simultaneously? I had similar rev issues before replacing my coils years ago. As far is the ticking it doesn't seem out of the ordinary.
Old Aug 9, 2011 | 01:24 PM
njmaxseltd's Avatar
Seriously?
I'll say it again, a back fire is usually ignition related.
Old Aug 11, 2011 | 10:11 AM
Swazey's Avatar
listen at your air filter, might be more audible. mine goes tick tick tick... tick tick tick.. etc
pretty sure thats normal, anyone else?
Old Aug 11, 2011 | 10:27 AM
maxxxdout's Avatar
i dont think so because it didnt always do that... but any other input would be helpful.
Old Aug 11, 2011 | 10:42 AM
isandres8884's Avatar
thats happening to my max 2 i have the same problem please help,. i
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
msellas
Sep 23, 2015 09:16 PM
