question about why rear shock is moving.
Old Aug 9, 2011 | 04:56 PM
TravisCadello's Avatar
i just put my drop springs and new shocks on the 99 maxx and got on highway it still has a shake and when i hit a bump the rear left shock makes a noise like its loose.
i checked it and when i bounce on the car the shock in the center and center nut moves around and the other side doesnt. is their something i forgot when installing them?
i can tighten the center nut as much as possible and it doesnt get better.
any help.
Old Aug 9, 2011 | 05:10 PM
MAXIMA_STYLE's Avatar
Bad bushing?? Did you replace just shock and spring or entire setup new bushings bearing etc etc??
Old Aug 9, 2011 | 06:43 PM
Flava_24/7's Avatar
Boosted Panda
any help.
Yes, you didn't assemble it correctly.
You sure you didnt maybe leave out either item #6 or #7?
Old Aug 9, 2011 | 08:28 PM
damn i didnt put number 3 back in and i definitively didn't put the number 6 nut in i didn't know their was even thread down their for it.
Old Aug 9, 2011 | 09:01 PM
the new struts came with two nuts i was wondering why, one was like a circle with a flat surface around it. someone help me figure out how it goes back
Old Aug 10, 2011 | 08:33 AM
Snypa's Avatar
if you follow the pict flava posted, you should be golden. Just place everything back in that order and then tighten. Make sure you have every single peice in that pic.!!!
Old Aug 10, 2011 | 11:18 AM
Flava_24/7's Avatar
Boosted Panda
Number three is just a paper seal, but number 6 is not a nut it is a bushing.
Only one nut is used, if they gave you two it sounds as if the other nut has the flat surface to be used if you dont have the #1 washer.
Its not very difficult, just reassemble everything just like the diagram I posted.
Old Aug 10, 2011 | 12:31 PM
IN that case i did everything correct except for the paper bushing. could that little bushing make that big of a difference?
Old Aug 10, 2011 | 12:43 PM
Flava_24/7's Avatar
Boosted Panda
Obviously it does. That little bushing serves a purpose as well as fills up that space.
When the strut assembly is corractly assembled, its a very tight setup, without having that bushing theres unfilled space. Since the threads on the struts piston only go down so far, you cannot sipmly tighten it all the way down to eliminate that space.
Take it apart and do it right.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
