Camshaft Position Sensor
Old Aug 23, 2011 | 09:06 PM
rhonster's Avatar
Where is this located and what tool(s) do you need to get it off. Thanks.
Old Aug 23, 2011 | 10:37 PM
Please search.
Old Aug 24, 2011 | 12:10 AM
97vqi30's Avatar
haha^^^^
Old Aug 24, 2011 | 06:45 AM
rhonster's Avatar
The camshaft position sensor is located on the front timing chain cover. Facing the passenger side of the engine it's the sensor located a couple inches to the right of the side engine mount and a couple inches directly above the adjuster for the pulley to the AC and alternator belt. There is nothing else in that area. Don't know the tool yet though.
Old Aug 24, 2011 | 10:30 AM
maxed_out_99's Avatar
A 10 mm socket and a long thin screwdriver for the connector
The ckps that was mentioned above is for top dead center ONLY not ignition timing that one is located next to the transmission bell housing behind the radiator on the engine block one 10 mm bolt an a 3 wire connector
Use the long thin flathead to gently pry the connector and sensor apart DO NOT damage the connector
I hope this helps
Old Aug 24, 2011 | 04:12 PM
johnmax98's Avatar
This is what leaks oil eventually, right? I heard the o-ring needs to be replaced when that happens...
Old Aug 24, 2011 | 04:26 PM
felorojas14's Avatar
Yea theres no need to replace it if its still functioning. Once you remove it youll see an o-ring at the end of it..you can remove the o-ring and take both the ring and sensor to a hardware store to find an oring which will fit properly at the end of the sensor..then pop it back in..done deal...Quick cheap EASY fix...
Old Aug 25, 2011 | 02:23 PM
Polar's Avatar
Are you having a problem with it? Mine died a couple of years ago and the car wouldn't start, but it gave the correct diagnostic code and was an easy fix.
Old Aug 25, 2011 | 06:36 PM
I hope this helps
I fail at reading I thought it was the crank sensor OOPS I suck
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
