What a productive day today (For my Maxima)
Old Aug 29, 2011 | 08:38 PM
kroze's Avatar
- Replaced (2) front wheel studs - $4
One wheel stud was completely broken off on the front passenger side. On the driver side, one wheel stud was cross-threaded. I guess the person who works on this car uses the airgun and snapped one off and cross-threaded the other. Feels good to be riding on 5 lug nuts on each side again
- Checked front brake rotors & pads (Excellent condition) & Applied anti-squeal on front brakes - $6
My brakes was squealing at low speed so while I was replacing the wheel studs, I checked the rotors and pads. I guess both were changed recently because they're in excellent condition. I went ahead and apply the anti-squeal glue to the shim and pads and it's dead quiet now. No more squealing coming to a stop.
- Upgrade trunk spring from SE model - $10
I hate whenever I used the remote to open the trunk, it would open but not prop the trunk lid up. The solution was to replace the trunk tension bars from the SE model (the one with the spoiler) and it works like a charm. Now whenever I open the trunk, the trunk lid pop open like I have powered lift gate
- Removed center seat belt to fit trunk spring properly - $0
Well this wasn't necessary but the new tension bars was rubbing the center seat belt assembly. I figured since no one ever sit in the center seat anyway, why not just remove it completely? The car looks a lot cleaner now without the center seat belt and I eliminated the rubbing issue.
- Replaced broken rear driver side quarter panel - $10
Whoever own this car before me tried to replace the rear speakers but do so unsuccessfully. They end up breaking the plastic quarter panel trying to rip it off. I went ahead and replaced it. The car looks 100% now
Old Aug 30, 2011 | 08:31 AM
djslim85's Avatar
Very productive day indeed. Keep us posted with progress. Good luck with the new Max!!
Old Aug 30, 2011 | 08:42 AM
crz1's Avatar
I follow your post. I will the same to my car in some areas.
Old Aug 30, 2011 | 11:09 AM
kroze's Avatar
I'll be happy to answer any questions if you need help.
Old Aug 30, 2011 | 01:59 PM
DennisMik's Avatar
I have a question. When you open your trunk with the new springs, does the lid open all the way or just part of the way?
Old Aug 30, 2011 | 02:22 PM
kroze's Avatar
Does this help?
http://www.youtube.com/watch?v=rdQk3-kJB2Y
Old Aug 30, 2011 | 02:29 PM
kroze's Avatar
Meh, tinypic must have screwed up the video conversion process because it looks like my trunk doesn't open smoothly but it actually does.
N/m I reuploaded to youtbe.
Old Aug 30, 2011 | 09:25 PM
DennisMik's Avatar
I couldn't watch the video. Youtube said I had to log in and when I did, it said that "This video is private".
So, does the lid open all the way or just part of the way?
Old Aug 30, 2011 | 09:50 PM
kroze's Avatar
Sorry I marked it as private by accident. check it out now.
Old Aug 31, 2011 | 08:42 AM
DennisMik's Avatar
Thanks. I'm sorry that my question created extra work for you. A worded answer would have been fine, but the extra effort of the video was really appreciated. Thanks again.
Old Sep 1, 2011 | 02:32 AM
max ride 41's Avatar
wth are you talkin about??? plastic quarter panel???? and, you could've just tucked in the seatbelt instead of removing it.
Old Sep 1, 2011 | 03:37 AM
GGENIUS's Avatar
your quarter panel is on the outside body of the car. and not made of plastic. so really doubt you replaced your plastic quarter panel.
Old Sep 1, 2011 | 09:49 PM
your name says it all man...
Old Sep 2, 2011 | 03:31 AM
GGENIUS's Avatar
yeugh ugh ugh ugh ugh.
Old Sep 2, 2011 | 04:32 AM
Bassbreaker's Avatar
I assume you mean the rear deck in the car or the pillers which surround the rear glass?
Old Sep 2, 2011 | 06:42 AM
nselca2's Avatar
How exactly did you fix your trunk release? My trunk only opens by key....but when I try opening it by key or by the trunk release button I here the mechanism in the trunk trying to open the trunk.
Old Sep 2, 2011 | 12:28 PM
DennisMik's Avatar
There is a safety latch built into the trunk latch mechanism. Open the trunk and look at the latch mechanism (above the bumper, not in the lid) from the side, not the top. You will see a metal lever. When it is in the down (?) position, the trunk will only open with the key. In the up (?) position, then the trunk will also open from the remote. Flip the lever.
Old Sep 3, 2011 | 06:20 PM
stromm's Avatar
I have a 1995 SE and the truck doesn't pop open like that. Can the springs be adjusted? Sorry, I haven't researched this point, I figured the deck lid just wasn't supposed to pop up all the way.
Old Sep 3, 2011 | 07:03 PM
kroze's Avatar
I don't have an SE model so I couldn't tell you. It's probably because you have a spoiler and it added extra weight?
Old Sep 3, 2011 | 08:59 PM
DennisMik's Avatar
I'm pretty sure that there is no adjustment for the trunk lid springs, this question comes up every so often. There is a thread where someone put a gas strut (like the hood uses) to open the trunk.
Found the thread, but the pictures don't load anymore. Some others have posted pictures of their cars, so maybe between the op's words and other's pictures, maybe you can get an idea.
http://forums.maxima.org/4th-generat...on-bars-2.html
Old Sep 4, 2011 | 06:46 AM
GarageToys's Avatar
I have an SE with the spoiler & wondered why the trunk didn't pop up when remotely triggered. I debadged the trunk yesterday and pulled the lock assy out to paint it black. When I removed the carpet trim from the underside of the trunk, I got my answer. My trunk lid is covered in Dynamat which makes it too heavy to spring up.
Quickgtp
Apr 13, 2017 03:30 PM
Trin1j23
Aug 12, 2015 08:31 PM
Team STILLEN
Aug 10, 2015 04:29 PM
Jcof88
Aug 3, 2015 10:43 PM
