Wiring into Lighting System? 12v
Old Sep 1, 2011 | 03:14 PM
worldwiderecognized's Avatar
Anyone have a write up of how to wire a 12v connection into the lighting system? (for interior LED accent tubes)
i cant find one for our cars
Old Sep 1, 2011 | 04:43 PM
beatdown97's Avatar
just run your ground wire to a good ground(any metal bolt hole) and your power wire to the ignition switch fuse (i have used fuse jumpers before to tap into the fuse) and then runthose wires to your toggle switch and then run your wires to your leds where you put your toggle is your own idea but to keep the stock look id run it into your console inside the lid. or if you want to have it come on everytime you turn the lights on tap into your power wire for your lights. on the 4th g i dont know which wire it is but its a clean way to hook them up
kjlouis
Nov 24, 2018 06:09 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
