Tensioner Oil Feed Passage
Old Sep 8, 2011 | 09:56 PM
Trini Boom's Avatar
Org, I have been doing over my water pump and resealing my upper oil pan and decided to update my 95 tensioner and guide. Before Installing the TSB says to clear out the oil feed passage. I am doing this work in my backyard and I don't have an air compressor. Can comeone tell me exactly where this passage is located and if a can of computer air or something else I can try is sufficient enough to clear it? Thanks
Old Sep 9, 2011 | 04:36 PM
Dark_man_x's Avatar
You can see it once you remove the tensioner itself, IIRC the passage leads to the oil filter. So take the oil filter off and the tensioner then blow your compressed air down the tensioner passage and it should shoot out of the oil filter hole. A can of conpressed air should be sufficient pressure as long as its not too clogged lol.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
