timing chain removal question
Old Sep 10, 2011 | 10:11 PM
918noah's Avatar
I have removed the upper oil pan and would like to continue on with the timing chain cover removal. Can I put a board and jack under the crankshaft to support the motor and undo the motor mount through the timing chain cover?
Old Sep 11, 2011 | 12:30 AM
MaxJammin's Avatar
make sure its on those 8 bolts and you should be ok
Old Sep 11, 2011 | 07:14 AM
918noah's Avatar
Thank you for the reply. That is what I thought but needed some confirmation. And moral support.
Old Sep 11, 2011 | 11:25 AM
Dark_man_x's Avatar
yes should be fine. Have fun!
Old Sep 12, 2011 | 04:00 AM
Trini Boom's Avatar
I ended up just replacing the crossmember temporarily and let it support the engine. There will be no need for a lift then.
Old Sep 14, 2011 | 07:57 PM
918noah's Avatar
That is a great idea also especially since I am already using my 3 jackstands and a floor jack already was going to have to borrow another floor jack to hold motor.What are the recommended parts I replace when i R&R that timing chain cover? If its nissan part numbers or links would be awesome. Thank you.
Old Sep 14, 2011 | 08:03 PM
Dark_man_x's Avatar
I would do the front main seal, and the 2 half moon gaskets for the upper oil pan. Everything else is just going to be silicone sealant. Don't forget to make sure the 2 o-rings on the upper oil pan go back on, if they look worn then replace them. Oh and idk if you plan on it but I would replace the water pump while your in there.
Old Sep 14, 2011 | 08:20 PM
918noah's Avatar
I was planning on water pump after all car has 190,000 should i also do the timing chain guide and tensioner? what else why I am at it?
Old Sep 14, 2011 | 08:33 PM
Dark_man_x's Avatar
Yes I would do the main guide and tensioner, If you feel up to it change both secondary tensioners also just for peace of mind but those guides and ten. can get a bit on the pricey side from the dealer. Umm as far as behind the timing covers that about covers it. Most of the timing stuff on the 3.0s is pretty stout. I'm going to be putting an tensioner and water pump in mine next weekend after 310k haha.
Old Sep 14, 2011 | 08:58 PM
918noah's Avatar
http://www.courtesyparts.com/13070-t...1784_1785_1794&
Is this the correct part for my 1997 se?
Old Sep 14, 2011 | 09:06 PM
Dark_man_x's Avatar
Yep, that's it.
maxinout93
Oct 27, 2015 01:29 PM
max_speed97
Aug 26, 2015 07:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
mikekay
Aug 10, 2015 12:52 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
