Running Rough - Multiple Codes
Old Sep 12, 2011 | 12:30 PM
finkasaur's Avatar
Car has been starting to run rough lately. At times, when I'm coming to a stop it drops below 500 rpm and almost stalls. Changed CPS (ref) because of CEL code that i pulled and it got better for a bit but now still runs rough. RPMs jump up to 1200 for a bit then down to 600.
Here are the following codes (I don't think they are all bad but could be wrong):
P0150: O2 Sensor b25 / closed loop bank 2
P0130: O2 Sensor b15
P0174: Bank 2 always lean
P1105: Map / Baro Switch Solenoid
I'm hoping changing the O2 sensor just needs to be changed to correct this. The P0174 could be due to the O2 sensor being bad (I hope). The only reason I'm hesitating is because it hasn't even been 10,000 miles since I've changed them.
Any ideas before I go and change the sensor?
Old Sep 12, 2011 | 12:41 PM
Changing the O2's should solve the first two codes, might solve the third but probably not the fourth code.
P0174:
P1105:
Old Sep 13, 2011 | 05:55 AM
cashoit's Avatar
The car is tellin u what to do. Why u asking us?????
Get rid of the CEL then post again.
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
