One Deatschwerks 600cc Injector Sticking?
Hey Everyone,
My car has a weird problem. I have 600cc Deatchwerks Injectors and cylinder 4 says I have a missfire. I have oodles of coils so I tried 3 different ones with the same issue persisting. Also tried the bad coil in question in another cylinder.
So the coil is good. I unplugged the injector as its the middle front one and the issue still persists (5 cylinders firing out of 6 or so it sounds). Now the funny part. If the car idles for a while the injector will kick in and the car drives with no issues.
Does the injector just need a cleaning? I can bring it to be flow tested, cleaned and have the filter changed. Question is why does it run normally after x amount of time.
Any help would be appreciated. Can I leave the injector in brake cleaner overnight or diesel (herd diesel removes gunk fairly well)?
Need advice. Thanks
Need advice. Thanks
Interesting problem for sure considering your injectors only have approximately 12,500 miles on them. Maybe the previous owner lied to you, and they really have a lot more miles on them and need a cleaning? Just guessing here, but what about the wiring/clips right at the injector? Try wiggling the wiring and see if that fixes your problem.
How about calling Deatchwerks and picking their brain? Smart dudes there.
Good luck, and let us know what fixes your problem.
I had a similar issue with a Dw injector before. What I did to test that injector was unplug the injector connector on the cylinder and plug in another spare injector to make sure the wiring is good. You will hear/feel the injector clicking. For me that injector was not firing for some reason either. It also was an inconsistent issue where sometimes it would work and at other times it would stick closed and not fire.
I ended up sending the set of injectors to DW, they tested all of them, found one to be defective, replaced the bad one and sent them back to me.
Ok, well. I did a test today. First I took out the injector and pulsed it with 12v with some brake cleaner in it. The brake cleaner went through the injector. So that worked. Then I decided to swap out the injector with another side, the problem remained in the same cylinder (#4). So the injector is good and the coil is good. This leads me to believe that the o2 sensor is faulty. A couple fo days ago I got a code reader and checked them out. I had a code for bank 1 (I believe the front?) and cylinder 4 misfire.
I never thought anything of the o2 code but now that the injector is confirmed good and same with the coil I'm thinking the o2 is affecting that particular cylinder up until the o2 gets warmed up and is in the proper range.
I'm letting the car cool down for a couple of hours then I'll unplug the o2's and crank the car. If the misfire goes away then its confirmed that the o2 was the issue.
(firewall)
BANK 1
1 3 5
2 4 6
BANK 2
(radiator)
Thx guys,
Here is my update:
Swapped injectors from cylinders 4 to 6 (still have misfire on cylinder 4)
Swapped coils and tried many (still have misfire on cylinder 4)
Swapped spark plug from 4 to 6 (still have misfire on cylinder 4)
Unplugged both o2 sensors (still have misfire on cylinder 4)
Why does it run like crap then run normal....This might be an expensive fix.
Here is my update:
a co-worker of mine had a 2002 tundra v6(im a toyota tech) with a misfire in cylinder 6, would only happen at idle,he tried everything except a compression test, turned out to be a cracked exhaust valve (had 175psi in all the other cylinders except 6 which had 120psi of compression) would run fine driving around,but misfire at idle.....not saying you have a cracked valve but you might have a compression issue.....
When I did the 00VI I soldered the connecters in. I'll check the voltage and see if I get anything but to be honest I'm leaning towards the Emanage or ECU as I doubt there is any circuit in between that provides the power. Although I do have a coil boost power supply, but that would affect all the coils not just one.
I'll do a compression test today and start from there.
I just replaced my transmission. Honestly don't want to replace a motor. I do have a spare with an upgraded oil pump but the time it would take plus I'm trying to sell the car so yah...
They do not make their own injectors, they take your stock ones and drill.
http://www.jimwolftechnology.com/wol...CTORSVSNEW.pdf
It's damn funny when a website puts that up to make there product look superior.
Thats funny, please stop posting this in the thread. The injector works. I have another issue. Trust me if I saw that in my injector id demand my money back. This is not how the Deatchwerks injectors are built.
your getting off topic, he swapped injectors with an injector that has no issues....we're not here to talk about DW products, start another thread, we're here to help him with a misfire issue, he swapped coils with known good coils,no change, he swapped injectors with another cylinder that had no issues, no change, he also swapped spark plugs, no change....unless there is an issue with his wiring, the problem is deeper than the basics, so unless you want to help with the misfire, i would stay out of it
check to make sure you have 12 volts at the injector with the key on, if you have access to an oscilloscope or a noid light, check your injector pulse width. also check for power at your coil connector. but i would do a compression test, its not a bad idea even if you find good compression....
I found the problem. It's the emanage. If you slightly bend the board the car runs normal. Otherwise you get a flashing red light. That's what I get for trying to sell her. Anywho, I'm going to bake the board so that the solder remelts and make new contact. Visually I can't see any ic out of place. It's definitely the board though. Couldnt be a simple problem. Never is with my luck.
Update:
Haven't baked the board as the plastic might melt. Going to bring it to work on Monday to have it looked at under the microscope and properly debugged. As of now though she is running properly.
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
I lied I won't burn it but damn...
am happy its not a motor
