Best rad flush
Old Oct 1, 2011 | 11:51 AM
holymoly's Avatar
Best rad flush
I followed this procedure two years ago on a thread I found here and it worked well.
I am up for another flush, but can't find that thread for a refresher.
Anyways, you empty the rad at the bottom and then disconnect one upper hose that connects to the rad. I then inserted a 3 foot plastic pipe into the open end of hose.
I added distilled water into the rad, then ran the engine.
The water exited into a large container.
The instruction was to continue adding distilled water until the water was clear of any old rad fluid, usually after filling with around 4 imperial gallons of distilled water.
The one step I missed is then do you drain the rad again, usually only water?
I was advised adding about 4 liters of concentrated rad fluid, this should arrive at a 50/50 mix as there was already 4 liters in the coolant system.
Anyways, I found this system great, no fluid on driveway, no mess.
Old Oct 1, 2011 | 07:20 PM
kel456's Avatar
so now that it is clear with distilled water then add 1 gal of 100% coolant and top it off with distilled water. remember to repeat rev engine and add DI water a few times.
Old Oct 2, 2011 | 07:43 AM
jholley's Avatar
The thread you are searching for is under the FLUIDS AND LUBRICANTS forum.
http://forums.maxima.org/fluids-lubr...ok-like-8.html
You made post 298 on that thread.
Old Oct 2, 2011 | 10:02 AM
holymoly's Avatar
got my answer couple of posts down.
Yes; when the system is 100% clean water, do drain the rad to make way for the 100% rad fluid. duh..
Old Oct 3, 2011 | 07:23 AM
njmaxseltd's Avatar
I just don't understand why people flush their cooling systems.
A drain and refill is all that's needed.
FWIW - In 185,000 miles, I've done THREE drain and refills.
Old Oct 3, 2011 | 07:25 AM
holymoly's Avatar
Are you still original rad?
user 11122324
42
Jul 18, 2022 03:35 PM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
