Engline Light Blink
car is running smooth, nothing physical that would indicate a major issue pending. A friend here thought it might be a weak relay or some moisture somewhere. Will do the scanner thing. I did give a guy a boost the other day... maybe its all the rain we've been having. Blink is not regular, just periodical. Any ideas on worst case scenario...?
Get a hanes manual, I am new to Nissan but all my older civics I have had when the cel blinked it was a code for OBD1 cars, watch the blink right it down like morris code and it should tell you your problem(if they are the same)
it's not throwing a code!!!!!!!! it's an occaisional one time blink of about 2 seconds, then disappears. I know how to run a manual code and also got a scan this am with no problems to report. The techie said, UNLESS there is a constant engine light, there is no way to determine a code or source the issue. I think it is/was likely a low a voltage scenario precipitated by a boost to a virtually dead battery.
fastcarny
10-06-2015 10:42 AM
Dennis Twohy
10-01-2015 06:01 PM
-ReLLiK-
09-08-2015 12:02 PM
