Guess the issue with this engine (video included))
Old Oct 10, 2011 | 06:34 PM
neocry's Avatar
The car: 2000 Maxima
The issue: Abnormal sound from the engine. It sounds like its got a supercharger (whine).
http://www.youtube.com/watch?v=IW6PR...eature=related
My guess/answer is that the AC Compressor bearing is on its way out.
What are your thoughts?
Old Oct 10, 2011 | 09:29 PM
DennisMik's Avatar
Could be the A/c compressor, or the alternator or the belt tensioner pulley.
Old Oct 10, 2011 | 09:55 PM
kroze's Avatar
use the screwdriver trick.
Old Oct 10, 2011 | 10:05 PM
neocry's Avatar
And what is this screwdriver trick you speak of?
Old Oct 10, 2011 | 10:57 PM
luke95gxe's Avatar
the butt of the screw driver to your ear the point on anything its like a stethiscope helps pinpoint noises or issues
Old Oct 11, 2011 | 07:09 AM
kroze's Avatar
use a big & long (hehe) screwdriver, place one end of the screwdriver touching to the suspected noise location such as the alternator, ac compressor, or idler pulley (Be careful not to touch any moving part). Put your ear on the other end of the screwdriver and you can hear the noise. The closer you are the the source of the problem, the louder it'll sound.
Old Oct 11, 2011 | 07:18 AM
njmaxseltd's Avatar
I'll take Alternators for $100 please...
Old Oct 11, 2011 | 11:33 AM
asand1's Avatar
Hows your power steering fluid? Sounds kinda like a pump. Remove the belts, turn each acc by hand to check for bearing feel. Start engine without belts to rule out engine noise.
Old Oct 11, 2011 | 03:42 PM
clive's Avatar
100% chingon
Sounds like the AC compressor bearing to me.
Old Oct 11, 2011 | 04:00 PM
GGENIUS's Avatar
if it was a PS problem wouldnt it be pretty obvious?
Old Oct 11, 2011 | 04:47 PM
MAXIMA_STYLE's Avatar
Sounds like ps pump on its way out...or ac
Old Oct 11, 2011 | 08:36 PM
neocry's Avatar
Thank you.
And thank you.
The alternator was replaced a few months ago with a new one.
Steering fluid is normal. The belts are new. I've also changed the the AC compressor but with a used one.
Old Jan 23, 2012 | 09:59 PM
maxjax's Avatar
I have same sound! whats the fix??
01, same sound, just started. I hope you are still on here, need help with this.
Old Jan 23, 2012 | 10:20 PM
maxed_out_99's Avatar
yup.
or you could also start it have a buddy turn the wheel back and forth to see if the pitch changes drastically you'll know right away by the sound if its the p/s pump
nissans are notorious for p/s leaks
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
boomerbrian
Nov 8, 2015 05:10 PM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
