timing ring
Old Oct 11, 2011 | 12:40 PM
315max's Avatar
timing ring
hey guys, throwing a crankshaft position sensor code, i looked at the timing ring through the sensor hole and there's some teeth that are chipped. my question is, does the timing ring remove from the flywheel?
Old Oct 11, 2011 | 12:49 PM
aackshun's Avatar
Yes.... But no....
It's a wierd bolt.
Old Oct 11, 2011 | 12:52 PM
315max's Avatar
what is it? like a torx? i have almost every tool ever needed...
Old Oct 11, 2011 | 12:53 PM
aackshun's Avatar
I'm looking for pics... H/o
[edit]
For future reference....The automatic trigger ring is WELDED and the 5mt is bolted on.
and yes... the 5mt fw is on the right....
Old Oct 11, 2011 | 12:57 PM
315max's Avatar
thanks for the info. manual here thankfully. im gonna try to weld the teeth back in and grind the welds down
Old Oct 11, 2011 | 01:12 PM
aackshun's Avatar
Uhhhh
Good luck, you have to have it EXACTLY right.
Worse comes to worse you can buy my FW
Old Oct 11, 2011 | 01:22 PM
cashoit's Avatar
id get a replacement flywheel and save the headache.
OP:
U prolly jus need to replace the sensor.
Old Oct 11, 2011 | 03:40 PM
clive's Avatar
100% chingon
Welding and grinding is going to result in some degree of imbalance, and right on the rim, where imbalance has maximum effect. Any imbalance will wreck the bearing nearest to it. I would be looking for a junker to get one from.
Old Oct 11, 2011 | 04:10 PM
GGENIUS's Avatar
this is you. welding your flywheel.
http://www.autoblog.com/2011/10/10/m...share_facebook
Old Oct 11, 2011 | 07:59 PM
315max's Avatar
its not my idea to weld the cogs. thats my dad b****ing at me for wanting to spend my money on an aftermarket FW. so if he effs it up he can buy me everything that gets effed up...praying for a vq35
Old Oct 12, 2011 | 08:42 AM
clive's Avatar
100% chingon
Well, if he wants to try some real welding, try welding the fuel tank . . .
Old Oct 12, 2011 | 09:04 AM
njmaxseltd's Avatar
How do the teeth on the timing ring get chipped when the only thing "looking" at them is a hall-effect sensor?
Old Oct 12, 2011 | 09:08 AM
aackshun's Avatar
That's the real question to ask, but oh well aint 'ish he can do about it now.
Old Oct 12, 2011 | 02:02 PM
Roosky's Avatar
A machine shop would probably be able to help you with that and will make sure it's balanced afterwards
Old Oct 12, 2011 | 02:45 PM
315max's Avatar
really? why would you even suggest something like that? even if you're just messing around that's f***ed up.
Old Oct 12, 2011 | 02:46 PM
315max's Avatar
there was a piece of metal from my old transmission that i missed and it was pinging around and messed up the timing ring. no big deal, now its just time to upgrade
Old Oct 13, 2011 | 01:13 PM
clive's Avatar
100% chingon
It's called sarcasm.
However, I have actually welded fuel tanks. You fill the tank with water first.
Old Oct 13, 2011 | 01:17 PM
Br0nz's Avatar
yeah then just drill a hole in the bottom to let the water out!
maxfever1987
Nov 19, 2016 08:01 PM
umnitza
Sep 1, 2015 01:03 PM
95Maxi
Aug 25, 2015 08:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
