ebay USB V1.4 ELM327 OBDII Scanner
Old Oct 12, 2011 | 11:21 AM
kel456's Avatar
anyone got the ebay ELM327 OBDII Scanner to work?
Old Oct 12, 2011 | 01:11 PM
kingw323's Avatar
I am wondering that same thing. Almost seems too good to be true since they are only a quarter of the price as the others.
Old Oct 12, 2011 | 01:12 PM
MAXIMA_STYLE's Avatar
So if its onlt quarterthe price test it out...
Old Oct 12, 2011 | 01:21 PM
Shift_A32B's Avatar
I got the ELM327 OBDII OBD2 V1.4 Auto Car Bluetooth Diagnostic US
Works good, no complains.
http://www.ebay.com/itm/ELM327-OBDII...item27bc38ff1b
Old Oct 12, 2011 | 01:37 PM
L_U_D_I_AMaxima's Avatar
I have one, works good, pretty much ideal for reading the codes quickly and resetting the light...
the software which came with it suck, but you can find some free software online...
Over all it was a good investment for me... before I used to go to autozone and ask for a "free check engine light" but sure after a couple of trips I also got the "free attitude" from the people who worked there...
I would recommend 100%
Old Oct 12, 2011 | 01:55 PM
kel456's Avatar
is yours a usb. i have a usb one running on Vista communication port com 3 says good and shows green but the interface shows red with an error. it's the same result with several software that came with it.
Old Oct 12, 2011 | 02:34 PM
no i have the bluetooth version... I can't remember the name of the software which I am using, but I had to change a couple of softwares until I found one that actually worked ... so far i've had this scanner for about a year and no problmes... you have to find on which port it actually connect on the computer and then set the obd2 software to read/write on that specific port...
Old Oct 12, 2011 | 09:00 PM
99superblackmax's Avatar
What's the point of buying one? All you need to do is turn the little screw on the computer back and forth and the cel li
Old Oct 12, 2011 | 09:03 PM
Light will start to blink slow then fast. Come back to the site and pmohr has put a cel decoder up. All the codes are here and free. Sorry on my phone and it decided to post too early
Old Oct 13, 2011 | 06:23 AM
kingw323's Avatar
I have used the little screw method countless times and it has helped me out immensely. I am just curious as to how accurate and helpful the data readings are from a scanner, specifically the cheap elm327, along with some decent software.
Old Oct 13, 2011 | 06:35 AM
I don't believe there is a ''little screw" method on the 5th gen?
Old Oct 13, 2011 | 08:31 PM
Ah, gotcha. I would assume it would pretty much be the helpful as the scanner used at o'reilly or another auto parts store. Which is fine, but the codes on the site are more helpful.
Old Oct 25, 2011 | 12:05 PM
kingw323's Avatar
Does anyone know the trick to connecting the elm 327 to the android app Torque? The adapter is paired with my phone but will not connect my ecu to torque.
Old Oct 26, 2011 | 03:50 AM
95nissmax's Avatar
I have the usb 327 obd II having trouble
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
