Proper size tires for 16 x 7.5
I have a set of Borbet wheels and tires with 205/60-16 tires that have always seem a bit Beffy...just ALOT of rubber.
What tire size should I be buying ?
The wheels are 16" x 7.5"
I'm running 225/55R16 on my 16x8 rx7 wheels. The speedo is accurate with this size.
Note that the tires in my sig are 225/50R16 and they made the speedometer read about 5 mph faster than I was actually going/
Considering that you're supercharged im assuming you want a bit wider tires. I'd recommend 235/50 which is super close to overall stock diameter. There are many different width/aspect ratios that can be picked from in this rim size that will have the same overall diameter. use this tool to pick out what you want...
http://www.1010tires.com/TireSizeCalculator.asp
sotck size is 215/55-16.
that tire is too narrow for that wheel but the overall diameter is very close to stock so it appears meaty because it is a 16" wheel.
-matt
16" performance tires in our size have been disappearing over the last decade. Used to be a dozen 245/45/16's you could find but no more in street rubber. Now the 225/45/16 are also nearly extinct. Everybody's adopted 17" wheels as the minimum unfortunately.
Im really not looking for a performance tire. I just need an all around good size tire to use on my 16 x 7.5 rim. The size im using now jsut seems beefy on the side walls
-matt
-matt
I have a set of Z32 wheels (16x7.5) with 225/50/16 and they are perfect. 245/45/16 are a bit shorter still, but they came on the rear TT wheels, 16x8.5. Looks damn hard to find a street tire in that size as mentioned.
225/50-16 fit great on 16x7.5 wheels like others have stated. Sidewall is still narrow yet you do don't feel every bump in the road.
05' MaximaMan
Oct 8, 2017 06:36 PM
Serotta33
Sep 17, 2015 12:14 PM
