Huge power loss! Need 00vi guru guys!
If its lit up, that means its acitvating which means its seeing an immediate ground when powering up, not at the designated RPM switch.
Which RPM switch do you have and how is it wired up to the VSS?
clicky clicky, light is on at ALL times, just to be redundant, not an idoit lol
http://forums.maxima.org/4th-generat...tall-help.html
I see a white wire going to the green, thats your rpm signal right? And its going to the RPM switch?
I then see a red wire which Im assuming is the 12 volt power source and its also going to the RPM switch?
The other wire is see is that yellow one that goes from the VSS to the RPM switch?
I dont see a ground nor do I see a 12volt power wire going to the VSS, or is it getting it from the wire harness?
Well those pics dont really show much.
And for the red I have it running to the power souce, is this wrong?
And I have the yellow I believe for the ground, not 100% sure since it's 10pm at night and I'm not working on my car currently. wrong again?
Hey and if you don't mind, can you PM me your number since I hardly have time to get on here?
Really? Its not that hard to get going. Have you messed with it any since then?
Where are you getting your rpm signal from?
Also, what switch are you running? Ive asked before but you never asnwered, I also asked to see the dip switches.
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
