Starter Problem
Old Oct 25, 2011 | 08:02 PM
nselca2's Avatar
Starter Problem
For a while now, my car has been cranking over slower and slower during startups so I anticipated for the starter to go out. Its been about 2 weeks or so since I initially realized the slow starting until today where the car wouldnt even start but would only make a single click, not even crank over unless it was pop-started. Charged the battery in the car and even swapped the battery that was in the car with a known working one but still no dice so Im going to go ahead and buy a new starter. Only thing I was unsure about is that my 4th gen has an 01 ae lsd tranny. Does that have any affect on which starter I need or will a 4th gen starter bolt up perfectly fine? FYI: Car is a 97.
Old Oct 26, 2011 | 07:04 AM
slfalco's Avatar
Check the battery and alternator cables for corrosion, especially the large ground cable. Typically starters don't start slowing down before they fail, although I suppose that is possible.
Old Oct 26, 2011 | 10:46 AM
WesCTR's Avatar
i just recently replaced a starter on my 95 and it was definitely slowing down for weeks before it just wouldn't turn over anymore. put a new starter and had no issues. that was with me needing a new battery as well.
Old Oct 26, 2011 | 10:51 AM
imports_only1's Avatar
I replaced my starter last year and it was slowing down before it died. First it would take 4-5 cranks to start it, then 5-6, then 6-8, and one morning....NOTHING! Replaced starter and it started like it was new.
Old Oct 27, 2011 | 04:44 AM
wirelessdude04's Avatar
Yea sounds like starter is about to take a poop. Get a new starter and sand down all your grounds to insure proper connection. Also when you did the 5 speed swap if you did it was the bellhousing sanded down? That's one of the biggest issues with our maximas and starting.
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
jwright36
Sep 8, 2015 11:45 AM
