Need some help with, what I guess is an odd issue...
Old Nov 1, 2011 | 08:42 PM
4th_Gen_SE's Avatar
Recently I noticed my car running like crap, it had also been making an exceptionally foul odor from the exhaust. not having time to check what was up I parked it and began driving my Taurus. After consulting a few mechanics and getting a lot of mixed answers i thought i'd come back home on the Org. Anyway, back to the point, the symptoms:
- Lots of white smoke from the exhaust but only after the car warms up.
- Oil smells like gas
- Engine miss
The odd things:
- Coolant in radiator and reservoir are fine
- Oil was slightly low, though not enough to make a difference
Work done in the last 3 months:
- 3 new injectors and coil packs in the rear bank
- Throttle body, EGR, IACV, and Intake cleaned
- 6 new NGK Iridium Spark plugs
Mechanics weren't sure but wanted to do Heads and Gaskets, I think an injector may be leaking into the oil and possibly destroying a piston ring or two seeing as two cylinders still weren't firing...Any help is appreciated before the car is sold, maybe a Max can be saved...
Old Nov 2, 2011 | 06:44 AM
bobflood's Avatar
White smoke usually means a coolant leak into cylinder via bad head gasket. Do a cooling system pressure test; can rent/borrow equipment at Advance/Autozone.
Old Nov 2, 2011 | 06:58 AM
asand1's Avatar
Plugged cat. Eccesive back pressure = more blow by into crankcase and crappy running.
Bad cat smells like rotten eggs.
Old Nov 2, 2011 | 10:10 PM
skim35's Avatar
That sounds like either blown head gasket or cracked cylinder head.
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
