Car shifts, wont move 5spd
This actually is much better than the IPS snapping ... could'a been much worse!That clutch will buff right out ... why you
No joke EPIC fail!
Trans mount? Mine does the same thing and has for a longggg time. I think it may partially be do to worn bearings = more play. I am sure though that it has something to do with the fact that our 5mt's are rod shifted too .... wtg Nissan! lol
This actually is much better than the IPS snapping ... could'a been much worse!Trans mount? Mine does the same thing and has for a longggg time. I think it may partially be do to worn bearings = more play. I am sure though that it has something to do with the fact that our 5mt's are rod shifted too .... wtg Nissan! lol
There are multiple mounts.....
Any one failing can call for shifter movement, you have a rod driven shift linkage, you're going to have NVH and movement, only way you can get rid of it torally is... to go 6mt *trollface*
A week after I got the new clutch in My tranny decided to take a dump. 1st was hard to get in and out. 2nd was ok. 3rd grinded going in real bad. 4th would pop out. 5th would pop out too when I could even get it in that gear. And reverse grinded bad too.
So I had a spare 5spd tranny (non VLSD). I didnt want to use it because I didnt know its condition. I had the time so yesterday I threw it in along with a new drivers side axle. Took it for a drive this morning and surprisingly it shifts smooth in all gears.
Now its time to find parts and rebuild the VLSD...unless an HLSD tranny falls in my lap for cheap.
had this happen to me in a 99 eclipse but i was downshifting i would almost bet its ur clutch it probaly decentigrated. just hit the bellhousing lightly with a hammer and see if any clutch dust comes out out smell for burnt clutch
No ****? Was it the pic that gave it away?
Lakersallday24
Jun 16, 2019 01:35 AM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 14, 2015 12:31 PM
some just lack reading skills
