ok before i part this car out !!!
Old Nov 8, 2011 | 05:18 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
for 6 months now i fix something and something else goes wrong
i still have a p1130 code after changing the swirl control valve control solenoid. what else could cause the p1130 ideas ?
Now the new problem cause there always has to be a new problem. When i step on my brakes the driving lights, parking lights, and dash lights all turn on while the brake is depressed ! can you believe it ! I can thoughts ? im about to part this thing out and buy 6th gen
well maybe not part it out thats just too much work. its drivable, its inspected, and someone else can part it out if i go that route. all i want is 1500 for the car is i cant fix this. LOTS of mods and parts youll make 1000 in your pocket easy. its a 5 speed, tein/gr2 suspension, short throw, custom shift and ebrake boots (black leather gray stitching) 5th gen anniv shift ****, smoked tails, black leather interior 9 out of 10, bose HU, internal switches work, heated seats, warpspeed y pipe, fidanza flywheeel, oxygen sensor mod for cali cars to be federal spec'd, NEW radiator, engine strong lots of good parts on it. The body definitly shows its age your not not making money on the body, windows are tinted and still perfect, rims perfect tires shot, so after dropping 1500 on it you can easily at a minimum clear 1000 in your pocket on this car. ill let you guys know what im doing with it but for the moment ill give it one more shot at life :-)
Old Nov 8, 2011 | 08:09 AM
DennisMik's Avatar
This kind of thing happens when a 1156 turn signal lamp gets put in the tail/brake light socket where a 1157 bulb belongs. It can also happen when the filiments inside the 1157 tail/brake light bulb warp and touch each other.
Take out the tail/brake light bulbs one at a time and step on the brake pedal and see if the problem goes away. When you take the bulb out, look at the bottom and verify that it is a 1157 bulb. A 1157 bulb has 2 contacts on the bottom.
Lakersallday24
Jun 16, 2019 01:35 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
