Auto transmission issue
Old Nov 11, 2011 | 03:21 AM
dgoodhue's Avatar
My auto transmission has a problem at part throttle off at low speeds (unto 20-25mph). If I give it light throttle and then try to accelerate (i.e. half throttle), the transmission sort hangs up, its almost like like its stuck between gears/torque converter slipping. If I give it 3/4 gas or so it will downshift to first but it downshifts harshly, almost bangs. If go off the time hard or WOT it works perfectly fine, at WOT my shift are good as well. It been like this since I have had my car (~122K miles), it now has 150K The previous owner changed the oil every 30K miles with synthetic fluid.
I am not quite sure what is happening. Should I have the transmission flushed or just change the fluid a couple times? Or it is this some computer control issue?
Old Nov 11, 2011 | 06:34 AM
njmaxseltd's Avatar
Check the TPS and the drop resistor.
Old Nov 11, 2011 | 07:49 AM
Shift_A32B's Avatar
Check the drop resistor. Sometimes the wires become to sensitive if you move them around.
Old Nov 11, 2011 | 10:45 AM
maxed_out_99's Avatar
All above posts and clean your maf
Old Nov 11, 2011 | 11:18 AM
2000_MAXIMA_KING's Avatar
This.
Old Nov 11, 2011 | 12:09 PM
Nikkitn35's Avatar
My car was also doing this so I replaced tranny and now my car will not start. 98 maxima. I got two codes on it and replaced the sensors for those..check engine light went off and still it will not start... it will turn over but will not crank... so frustrated. I drove it into garage so it was running good before we changed tranny. Any ideas?? Its my only vehicle so I really need to get this thing fixed!!! I love my Max
Old Nov 11, 2011 | 01:29 PM
maxfever1987's Avatar
more than likely when you change your tranny you didnt sand down the ground points, therefore you have no ground signal, you MUST and down mating points and reinstall your tranny, wat codes did you have?cam and crank sensors?
Old Nov 11, 2011 | 08:02 PM
KiNgJaMEs's Avatar
+1 take off and sand mating surface, re-install and enjoy
Old Nov 13, 2011 | 04:40 AM
dgoodhue's Avatar
It got a lot better when I adjusted my TPS and IACV values via FSM procedure, I did them as close as I could.
Old Nov 15, 2011 | 12:30 PM
Nikkitn35's Avatar
Thank you all so much! I have someone sanding it down for me now. I will let you guys know if it fixed it. The guy I got to fix it for me said he could definitely fix it for me.... Thank goodness! The codes were p0110 and p0115
Old Nov 15, 2011 | 12:32 PM
Nikkitn35's Avatar
Codes p0110 and p0115
sctludwig
Sep 1, 2022 01:32 PM
pktaske
May 6, 2016 07:49 AM
Maxboy23
Sep 4, 2015 06:04 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
