Ebay Headers
Old Jan 22, 2012 | 07:24 AM
  #121
D I R T Y I 3 0's Avatar
Originally Posted by CMax03
So is this Vehicle up and running properly since your mechanic installed the rear header manifold? You posted a video with your car running running pretty badly and I'm curious if the Max/I30 is humming along now?
Oh the recent exhaust video? that was bad?? haha it runs like a champ besides that small exhaust leak that makes some noise. Definitely faster
Old Jan 22, 2012 | 11:48 PM
  #122
CMax03's Avatar
where's your exhaust leak at?
Old Jan 23, 2012 | 05:40 AM
  #123
The flange where the muffler and B-pipe meet. It's a very small leak due to how rusted it is
Old Jan 23, 2012 | 06:17 AM
  #124
CMax03's Avatar
remove the stud ring (If this is an OEM Muffler) and dremel the bolt holes out slightly to install the stainsteel cat gasket between the two and cure you problem.... Or have a muffler shop cut both flanges off and install two new flanges....or get yourself a new Bosal (NAPA) Oem replacement exhaust system...no matter what it's a simple fix! Once you fix that you're really feel your car pull harder since there's a disturbance in the exhaust flow with that leak!
Old Jan 23, 2012 | 06:34 AM
  #125
Gotcha, the muffler has a lifetime warranty from meineke and since I don't have a dremel or sufficient tools we're just going to take it there and ask them to do it for free. I wonder how much of a gain there will be, it's quite small of a leak but I'll see. Thanks
Big bump...after a few months I believe there is now another leak. Ive been away, and my parents said one day it was quiet and the next day its making a lot of noise. It idles fine so my guess is the gasket at the y-pipe and cat is done.
Is there a gasket sealant anyone recommends? I'm not home so I can't fix it so it would require shelling out cash for them to fix this and Im sure more problems will inevitably come.
Old Mar 27, 2012 | 08:04 PM
  #126
hornepirate's Avatar
Just the rtv red high heat is what i use on exhaust gaskets.
Old Mar 27, 2012 | 08:20 PM
  #127
VisciousMo's Avatar
this
Old Mar 27, 2012 | 08:33 PM
  #128
so apply on the outside?
Old Mar 27, 2012 | 09:58 PM
  #129
ShocknAwe's Avatar
hight temp orange is MADE for gaskets like that. Although I dont know why you would use RTV anyways, eventually it will fail
Old Mar 27, 2012 | 10:05 PM
  #130
VisciousMo's Avatar
the mating surface. I didn't read the whole thread to see if you used the OBX gasket.
I re-used the OEM and applied a lot of RTV
Old Mar 28, 2012 | 04:45 AM
  #131
Yes I used the gaskets that came with it. Old gaskets were done
Old Mar 28, 2012 | 09:08 AM
  #132
Dsquared97maxse's Avatar
can you instal an ebay y-pipe with the stock exhuast manifold?
and cant wait to see how it turns out DIRTYI30
Old Mar 28, 2012 | 01:07 PM
  #133
CMax03's Avatar
The fix is using OEM SS gaskets Order some and you'll be good till the end of time! That exhaust RTV is BS and a waste of time, Buy yourself a few OEM cat gaskets and call it the day! I've using the same cat gasket for 9 years no problem yet
Old Mar 28, 2012 | 01:31 PM
  #134
No. warpspeed y-pipes work with stock e.manifolds though
Old Mar 31, 2012 | 09:06 AM
  #135
Shoot... thanx tho lol i was wondering if i could go with the cheaper one. but guess not. not feeling replacing the headers but i might have to anyway. the rear one has a small leak.
Old Mar 31, 2012 | 01:08 PM
  #136
schmellyfart's Avatar
Yes you can, but there are no guarantees on the fitment.
Old Mar 31, 2012 | 06:24 PM
  #137
Might as well buy OBX Equal Length Headers
Old Mar 31, 2012 | 06:28 PM
  #138
Rods03Max619's Avatar
Agreed get the OBXs....
Old Jan 20, 2013 | 05:51 AM
  #139
Bump, does anyone know if OEM gaskets will work with these? My gasket is going out where the front header and Y-Pipe connect
Went to a Midas and a mechanic told me I need the aftermarket gaskets. He said I could try tightening the bolts more to seal it
So I have aftermarket headers + Y-Pipe, and a stock exhaust. will an OEM cat fit?
Old Jan 20, 2013 | 06:52 AM
  #140
GGENIUS's Avatar
well not literally how I said it. We looked at the quality of the welds and the bung seemed to be in the wrong place. The OBX weren't equal length either so my friend decided it wasnt worth the xtra flow and pain of installing headers and just went the y-pipe only route. Thats what I did too and im more than satisfied with the gains(only butt dyno as of yet lol) and sound from the Y only set-up. Im going to take my car to get it tuned here in a few days and ill be able to say exactly how much I gained with the NWP spacers and the Cattman Y.
youre gonna get a tune for the spacers and y? do you have an intake, or 2.5" or 3" catback too? or any other bolt ons? just curious.
Old Jan 20, 2013 | 08:23 AM
  #141
ShocknAwe's Avatar
I have quite a few things under my sleeve lol but decided to wait on the tune, AEM FIC, until I have the time/money to install the v2. If it takes much longer I am just going to get a SAFC in the mean time because I am running more rich than I would like ATM. In the process of replacing most of my ignition system and should be done by the end of today. OEM colis cost mucho deniro
Old Jan 20, 2013 | 08:49 AM
  #142
carsnwomen91's Avatar
And this is why I'm gonna get a mechanic to Delete egr and install my headers lol
Old Jan 20, 2013 | 08:51 AM
  #143
ShocknAwe's Avatar
Honestly the best opption if you have the money. They can do it in a few hours where as it would take you a day, possibly 2 with hand tools
Old Jan 20, 2013 | 10:29 AM
  #144
Is the OEM gasket a circular crush gasket? Im not sure if its supposed to work with my aftermarkets. Aftermarkets came with a triangle. Should I use both triangle and circular gaskets?
Old Jan 20, 2013 | 10:39 AM
  #145
GGENIUS's Avatar
such a waste of money
Old Jan 20, 2013 | 11:45 AM
  #146
Bump, sorry to interrupt your convo guys I'd just really appreciate an answer. There is just no groove on my Y-Pipe to put the OEM circle gaskets in.
Old Jan 20, 2013 | 12:14 PM
  #147
What you need is a 2" (or 2.25" I don't remember the diameter off hand) 3 bolt gasket for the ypipe.
Old Jan 20, 2013 | 12:25 PM
  #148
ok thanks
Well sheez, one of the three bolts on the header I snapped in half because the nut was cross threaded, so didnt even bother taking off the y-pipe
Im just going to send it into a shop and have them make gasket and replace it, I'm pretty tired of my hand tools and having no space to work on my car
So I am going to replace the front exhaust manifold gasket since these felpro ish blows. I'm going to go with Beck/Arnley multi-layered gaskets since they are OEM replacement. I think they should fit.
So procedure I have in mind
1) Remove positive battery cable
2) Remove coolant hoses
3) Remove radiator fans
4) Undo Y-Pipe. Not replacing these gaskets since I dont want to and believe they were already replaced
5) Undo 6 bolts on header
6) Reassemble it all
Going to soak the hell out of the 6 header bolts with WD-40, since I dont want busted bolts. However, they didnt break last time so hopefully Ill have the same luck here.
Any tips?
Oh yeah hopefully will have access to lift this time which will make life so much easier
Going to get a U-joint to get the bottom three header bolts since I used one of my friend's last time
Old Mar 15, 2013 | 03:27 PM
  #149
P0tter7's Avatar
i got them and i stil got them on my car. u feel the diff from the gett. the only problems i had were:
1 my holes for the back header were off. they were twisted about 1/4 inch so i just slated them. make the hole go right out to the edge of the flange. so bascly the bolt could just slide on to it.
2. were the down pipe sits it hits the oil pan so i had to smash it in alittle bit. but went well i like alot. when i do my motor swap im buing a new set. and giving these ones to my boy who just bought a max
Old Mar 15, 2013 | 03:31 PM
  #150
word, what gaskets are you using?
Old Mar 15, 2013 | 11:42 PM
  #151
Any tips?
Coolant hoses can stay on.
Old Mar 16, 2013 | 07:05 PM
  #152
Word, gracias sir
Bump, gasket was fixed awhile ago and that's solved
Now, there is this odd and loud exhaust rattling at 2500-3000rpm when gassing it. And when I let off from high rpms back down to idle I hear the same sound in that RPM range.
Notes:
- EGR is cloggeed
- Cat. is old (rusted)
- Y-Pipe slightly rusted, flex pipe looks fine. I think it's coming from there though (stainless steel my ****)
- Don't think it's a gasket, doesn't have the puffy, muffled sound of a gasket leak. Just a metal rattling
- And I'm missing the metal exhaust brace to hold up the exhaust lol. Hangers are all there though
Old Apr 21, 2013 | 01:42 AM
  #153
CMax03's Avatar
heatshields loose somewhere or cat coming apart on the inside......OH WHAT BRAND YPIPE ARE YOU RUNNING?
Old Apr 26, 2013 | 09:27 PM
  #154
Ebay Y-Pipe, all heatshields are off. Someone also told me the cat is going bad. I'll put my money on that then?
Old Apr 27, 2013 | 04:57 AM
  #155
Before i read this post I was gonna at cat but you took he words outta my mouth
Old Apr 27, 2013 | 07:51 AM
  #156
Zach-R's Avatar
I had a 200sx and the cat was falling apart inside. It sounded just like a heat sheild rattling. I actually removed almost every heat sheild on the car before I realized it was the cat. Lol.
Old Apr 27, 2013 | 11:21 AM
  #157
^ Oh ok, thanks. The cat it is!
Bump, so I'll now have time to fix her up. Am about to order the Cat from PartsTrain but I noticed this cat doesn't have the O2 sensor port. Do I need to have one with the port? There was one from Advance Autos, but it's 180...yeesh. Input?
OEM should fit eh? Y-Pipe --> Cat --> Stock exhaust?
http://www.partstrain.com/store/deta...?location=Rear
Old May 20, 2013 | 07:43 AM
  #158
So I have the new cat. with me...are the flanges supposed to be all crooked and ish?
Old May 20, 2013 | 08:45 AM
  #159
Ya, they're not in line but should fit like that
Old May 20, 2013 | 09:09 AM
  #160
Alright thanks, because I was flipping out lol
