Knock Sensor help
Old Nov 26, 2011 | 07:14 PM
JEFF6898's Avatar
Knock Sensor help
Anyone live near Panama City Fl that I can pay to help me change my knock sensor?
Old Nov 26, 2011 | 07:48 PM
skweaky's Avatar
I live in Opp AL. I'll help if it comes to that. Little over an hour drive though.
Old Nov 26, 2011 | 08:05 PM
2brosgixxer's Avatar
Thats an easy fix to do yourself. Just pull the airbox and all hoses off, sneak a 12mm wrench or socket with a swivel down under the intake manifold and unbolt it. There are a ton of threads on here of how to do it and many have pics.
Old Nov 27, 2011 | 10:45 AM
heathbresee's Avatar
you can do it man its easy
Old Nov 28, 2011 | 07:57 AM
JEFF6898's Avatar
I spent 2 hours and still can't even get the wrench on the bolt to even try and break it loose. I watched the video a dozen times.
Old Nov 28, 2011 | 08:12 AM
sow3r's Avatar
I'm in the same boat man. I've spent about 1hour trying to put the wrench on the bolt... I'm contemplating taking the whole IM just to get to that bolt.
Old Nov 28, 2011 | 11:37 AM
TurTLe*'s Avatar
#1 you dont use a wrench.
You use a 1/4 in or 3/8 in drive shallow socket, swivel socket and some extensions.
Old Nov 29, 2011 | 12:15 PM
Zubriski's Avatar
Have you considered just over-riding the KS altogether with a resistor? That's an easy fix, just be sure to use high octane gasoline...
Old Nov 29, 2011 | 10:47 PM
mpvibes's Avatar
IF U HAVE BIG HANDS, IT IS NOT EASY TO INSTALL THE KNOCK SENSOR. I have a thread on this. You will need the small hands of a 5-7 year old to install it.
Old Nov 29, 2011 | 11:01 PM
Agreed!! I put a ratchet on mine and had it out in about 30 seconds.
Old Nov 30, 2011 | 12:44 PM
DBear's Avatar
Big hands will make it hard (maybe impossible), but you don't need a child's hands either. The key is getting the sensor right in front of the valley out of the way. (I forget what it's called.) You can do that easily with a crows foot wrench or a flex head wrench to take off the nut that's on the underside of the sensor.
You'll get scraped up a little, but we should all be used to that.
Old Dec 26, 2011 | 02:58 PM
JEFF6898's Avatar
Finally changed knock sensor
Well today I decided one way or another I was going to replace my knock sensor. Ended up using the socket method. Couldn't believe it took me 35 minutes to swap it out. Last time I tried a wrench and got no where. Thanks for every ones help I was dreading trying again. Glad I did.
Old Dec 26, 2011 | 03:09 PM
Shift_A32B's Avatar
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
