99 maxima with rough idle
Old Nov 30, 2011 | 04:27 PM
carrottop's Avatar
My car has been idling really rough at stop and kinda jumps in rpms from 700-500.
pulling 4 codes and was just wondering what i should replace first.
P1320 Ign system primary
p0325 Knock sensor 1 circuit/ bank 1
p0140 oxygen sensor Circuit No activity detected
Bank 1 sensor 2
Circuit (bank 1)
pending
Car wasnt idling rought until i changed sparkplugs for regular maintenance.
Used new Ngk Laser dbl Plat 2647
Old Nov 30, 2011 | 05:19 PM
maxed_out_99's Avatar
i think you have a vacuum leak
Old Nov 30, 2011 | 07:47 PM
MAXIMA_STYLE's Avatar
I think he should check and make sure ALL o2s are connected... aside from that id say vac leak also....
Old Nov 30, 2011 | 08:08 PM
Excalibur23's Avatar
Old Nov 30, 2011 | 09:06 PM
Check your spark plugs and coil packs since the rough idle started affer that work.
Old Nov 30, 2011 | 10:26 PM
carrottop's Avatar
didnt verify gap on plugs. was thinking about swapping the coils out as my first resort but i guess a vacuume leak may be the culprit?
Old Nov 30, 2011 | 10:32 PM
carrottop's Avatar
http://www.youtube.com/watch?v=m07e_...eature=related
this isnt my video but is exactly what my vehicle is doing. Skip to 58 seconds if you dont feel like waiting for the first minute of his talking
Old Nov 30, 2011 | 10:44 PM
zach-eminem's Avatar
did you read the comments coils fixed his problem get oem nissan coils no ebay sh%$ 600 dollars for all six maybe get a deal through courtesynissan.com
make sure to mention you are from the org
Old Dec 1, 2011 | 05:58 AM
carrottop's Avatar
he didnt say coils fixed his problems. He said to check the coils and plugs because it started after I removed the coils and replaced the plugs.
Old Dec 1, 2011 | 07:26 AM
maxxxdout's Avatar
Old Dec 1, 2011 | 07:38 AM
njmaxseltd's Avatar
This is the reason for your rough idle. The primary means the error is on the ecu or low voltage side of the coil. Check the connections to the coils, make sure you didn't accidentally bend a prong when you plugged them back in. Also make sure the electrical connectors are all seated nice and tight. They have to snap in place.
Bank 1 sensor 2
Circuit (bank 1)
These errors have no effect on engine idle. The KS if it's indeed bad will pull timing back under hard acceleration to avoid engine knock. The O2 sensor in question is only monitoring catylist efficiency. It is not effecting engine performance.
Fix the misfire (p1320) first. Clear the error codes and recheck about a week later to see what pops up. If the KS or O2 codes come back, replace both sensors.
dank4us
34
Jun 10, 2024 03:45 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
