missing at idle
Old Dec 1, 2011 | 07:35 PM
heathbresee's Avatar
missing at idle
so i searched you guys threads and went and done evrything you have said to do.. this morning it was about 25 degrees and when i started my car it missed for about 30 seconds and stopped i got on here searched and found some answers but didnt work here is what i did i replaced coils spark plugs and wires any advice cause i started it again about an hour ago and it still did it also it only seems to do it at idle not when u give it gas
Old Dec 1, 2011 | 07:55 PM
also ive seen alot on here about the faces of the bose stereos not working at all cause of the resistors but mine hasnt worked for awhile and then came on today for the first time out of no where and i pressed ejct and it went out again any explenation>?
Old Dec 1, 2011 | 07:59 PM
Shift_A32B's Avatar
Clean Throttle body, egr tube, iacv, etc or fuel injectors can be really dirty.
Old Dec 1, 2011 | 08:05 PM
well i forgot to mention i did seafoam also today and i just replaced egr valve about a month ago and its got a pathfinder thottle body
Old Dec 2, 2011 | 06:24 AM
cashoit's Avatar
So it only misses at idle? And its NOT throwing any codes?
Check your IACV.
Old Dec 2, 2011 | 07:04 AM
theres a code but its for a temperature sensor
Old Dec 2, 2011 | 07:06 AM
cashoit's Avatar
get the codes off. The ECTS is only 25 bucks from the parts store and takes 5 min to replace.
Old Dec 2, 2011 | 07:15 AM
Shift_A32B's Avatar
Egr Temperature sensor?
Old Dec 2, 2011 | 08:49 AM
njmaxseltd's Avatar
also ive seen alot on here about the faces of the bose stereos not working at all...................... but mine hasnt worked for awhile and then came on today for the first time out of no where and i pressed ejct and it went out again any explenation>?
You've answered your own question within your question.
jmlee44
Oct 2, 2022 02:13 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
rbaker100
Sep 25, 2015 07:52 PM
