beater is throwing some codes
Old Dec 19, 2011 | 06:53 PM
Maximum Performance's Avatar
1996 Maxima SE 5 speed 176k miles
here are the codes
P0100
Code Description: Mass Airflow Sensor
P0340
Code Description: Camshaft Position Sensor
car starts fine, idle is OK, low rpm and light throttle works fine, but if you floor it, it starts hesitating/sputtering at around 4k rpm
do you guys think one might cause the other?
Which one do you think I should swap out first? could one effect the other? maf seems to be getting ok voltage
i searched for camshaft sensor, but it seems whoever had issues here with it had also issues with starting..weird
Old Dec 19, 2011 | 07:23 PM
asand1's Avatar
Ive read on here that a bad MAF will cause you to hit a brick wall at the 4K mark. There are some members here selling used OEM MAFS. Test the Camshaft Position Sensor and check it for metal clinging the magnet.
Old Dec 19, 2011 | 07:41 PM
KT3MaxSE's Avatar
Pretty sure you need a new MAF. With your description-mainly the middle RPMs hesitating along with a P0100 code. When I had these two symptoms I replaced MAF and all's been good for over 6 years.
For your other DTC P0340, not too familiar with that one. Have you taken a look at/around both these sensor's locations and related wiring/connectors? Take a look at those areas and see what you may find, if nothing questionable is found I'd get a new MAF. Then see if code(s) go away or just clear them after MAF install & hope P0340 stays away as new MAF will take care of P0100 for sure, maybe both-I just am not sure what or if there is any correlation between the two codes or not. Hope that helps.
Old Dec 20, 2011 | 04:44 AM
malamgir85's Avatar
Disconnect da maf sensor, go around da block n see if it still hesitate if doesn't its definately da maf sensor. Went through hasitation probblem 2 mons ago did wat I tolds u to try . Got da maf from ebay for $70 n problem solved. It might take care of p0100
Old Feb 27, 2012 | 03:29 PM
McSteve's Avatar
bump, buddy told me new maf and cps didn't fix it
Old Feb 27, 2012 | 03:46 PM
tigersharkdude's Avatar
OE MAF? Also check the harness going into both
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
