BAD CAT???
Old Dec 19, 2011 | 10:19 PM
max ride 41's Avatar
BAD CAT???
no, the cat did'nt claw up the couch. but i went for emissions today and failed all 3 tests. i put a used cat on from another 95 2 years ago and just 10 months ago she passed with no issues. it was warmed up and she runs great with no codes, i should've put some chevron techron in her and put in some premium 2 days ago b4 the test. the hc wac 621 and should be 0275, the nox was 6399 and should be 03600 the 3rd was only off a little. usually when all 3 are bad thats a cat??? i have api up the street that sells to nissan and said 186.00 picked up. should i do egr valve clean up as well??
Old Dec 20, 2011 | 12:48 AM
WesCTR's Avatar
You should buy my cat from my 97.
Old Dec 20, 2011 | 05:37 AM
wirelessdude04's Avatar
yea probably another cat might fix your issue. Jersey Law's suck!!
Old Dec 20, 2011 | 06:35 AM
njmaxseltd's Avatar
The cat isn't causing your emissions to be high. Your engine isn't running 100% clean.
Check the air filter, clean the TB & IACV, change the spark plugs, make sure you have no intake leaks, change the oil and test again.
Old Dec 20, 2011 | 07:27 AM
Nismo95Max's Avatar
+1 these steps make a huge difference. and luckily aren't expensive. GL!
Old Dec 20, 2011 | 07:39 PM
JtzMax's Avatar
Whatchyou say?
I agree .... usually a bad cat will be clogged so much it will not let the car run right. I don't think that is your problem here, it would be really rough and sometimes will even push exhaust toward the front of the car (not allowing it to pass through). You're oxy sensors ok? You said no codes, but ghost codes maybe? Scan it and see..... can't hurt
Old Dec 20, 2011 | 09:07 PM
no codes but my tech said most likely cat because the semi-precious metals inside the cat did'nt stop the bad emissions from going through. im going to clean the utb and iavc and look for loose or leaky hoses first, then i'll consider a cat.
Old Dec 24, 2011 | 09:07 PM
JtzMax's Avatar
Whatchyou say?
Not a bad start .... how's the air filter? So, I guess a cat can be bad and not be clogged .... right? Never really thought much about that, but don't see any reason it couldn't.
Old Dec 24, 2011 | 10:14 PM
2000_MAXIMA_KING's Avatar
When a cat goes bad its because somethings wrong with the car, fix the car first.
Old Dec 24, 2011 | 10:39 PM
Rods03Max619's Avatar
Or mileage, cats ain't meant to last forever.....
Old Dec 24, 2011 | 10:54 PM
They usually go out with mileage because of poor maintenance. Not saying thats the OPs case but buying a used cat is like buying used underwear.
Old Dec 24, 2011 | 11:13 PM
I bought one new from NISSAN cali no other route, but after ride totaled just got the Headers, we do emissions every 2 yrs, should find somebody who pass me for a fee...
Old Dec 29, 2011 | 09:10 PM
Trini Boom's Avatar
My god and how much did that cost you? I guess they are different from cali and fed?? But the site doesn't show that on courtesy.
Old Dec 29, 2011 | 09:30 PM
surban1's Avatar
+1 plus some fuel injector cleaner (i like si-1)
Old Dec 29, 2011 | 11:20 PM
Same price as my Headers like 850 with no HP gain....Damn Cali they wouldnt send me a aftermarket one and didnt have time to send to a relative then send it to me....
Old Dec 31, 2011 | 02:00 AM
well, i cleaned everything and she idles better. rpm's shoot up to 1200 and then even out at 1000 right away. so, gonna use some chevron techron and do the cat. allthough i find it surprising that just 10 months ago she passed emissions with no problems. dammit....
Old Dec 31, 2011 | 03:17 PM
rvalente's Avatar
I`ve just changed mine cat with the MagnaFlow Catco, works flawless... plug and play design!
chisam14
Nov 6, 2018 08:56 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
