How the heck do you get to the parking lights
Old Jan 1, 2002 | 08:40 PM
Mad Dhan's Avatar
I am doing that blub mod where the blub always stays bright for the parking lights. I did the passenger side but the drivers side is a mystery to me? There is no way a grown man can reach in from the top and pull the bulb out. Is there an easier way to reach the bulb From the top my hands are too big and i cant get enough leverage to reach the socket and twist it out???
Old Jan 1, 2002 | 08:45 PM
Sprint's Avatar
if you are talking about the light next to the headlight?
use a phillips head screw driver remove the screw on top.. next to the head light.. then pry the clearance light out.. its tricky... but you have to use force and pull it out.. its actually a little nub wedge in a hole.. you just gotta pry the lights out
Old Jan 1, 2002 | 08:49 PM
Vyrus's Avatar
That's exactly it. It will be quite tight at first but do not worry about breaking the casing. It is a ball-socket configuration right? Anyways it will be tight so pry it with a flat-head. I've done it so many times (rewires and experimenting with different bulbs) that when I unscrew the top screw it practically falls into my hands.
-Cyrus
Old Jan 1, 2002 | 09:03 PM
Mad Dhan's Avatar
i tried pullling it out, i pulled it out slightly and i can see that it is attached to another screw which in turn is attached to the headlamp. It does not want to come out by just pulling.
Now im gettin ****ed cause i already did one side and cant do the other.
Old Jan 1, 2002 | 09:04 PM
Sprint's Avatar
no its the one screw on top.. its hard to pry out.. thats why it seems like another screw.. but once you pulled the phillips on top.. thas the only screw
Old Jan 1, 2002 | 09:06 PM
Mad Dhan's Avatar
yeah i got the uper one out easliy but i feel it pivoting on another screw on the bottom. I know you guys must be right since you did it before buts it doesnt seem like its coming out.
Old Jan 1, 2002 | 09:08 PM
Sprint's Avatar
As brother Cyrus said.. get a big flat head and wedge it out.. put the flat down by the pivot ball and wedge..
Old Jan 1, 2002 | 09:24 PM
Mad Dhan's Avatar
Ahh Yes! Today I am a man . I used the flat head way, thanks to all you guys for helpin. Its looks so much nicer now. That was the hardest mod i ever did...looks like i gotta change my sig
Old Jan 1, 2002 | 09:28 PM
Sprint's Avatar
good job..
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
