turning off the check engine light?
Old Jan 1, 2002 | 08:57 PM
ocm2001's Avatar
how do you turn the check engine soon light without having to go to the dealer?
Old Jan 1, 2002 | 09:13 PM
KWheelzSB's Avatar
ECU resources
Check these out:
http://vbxmaxima.8m.com/ecu.html
http://vbxmaxima.8m.com/ecudecoder.html
P.S: The "check engine soon" light came on for any number of reasons, from minor to serious. If you care for your car, your goal should be to find out what caused it to come on, in addition to resetting the light. Use the "decoder page" for that.
Old Jan 1, 2002 | 11:34 PM
Eric L.'s Avatar
Re: ECU resources
Originally posted by KWheelzSB
Check these out:
Yeah follow the instructions, but don't reset the light before pulling the code. The light comes on for a reason, so you might as well find out what the possible problem is.
You don't want to be driving around with engine misfire or something else which will wreck the catalytic converter. A bad O2 sensor over time will cause the ECU to function in open loop mode at all times, and the fuel mixture may be rich enough to foul the cat if you don't fix the problem.
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
doobadoo
Aug 15, 2015 06:43 PM
Flores94
Aug 11, 2015 12:53 PM
