Replacing front electronic engine mount with a standard one?
Old Jan 23, 2012 | 10:17 AM
beegeezy's Avatar
Have any of you guys replaced the front electronic engine mount with one from a base model or manual transmission? I'm mainly asking because of the large difference in price between the two. I don't care if I get a slight amount of additional vibration with the standard mount. I guess someone with a automatic GXE would be a good person to ask since they came with standard mounts...
Just trying to save a buck, so any help is appreciated.
Old Jan 23, 2012 | 10:53 AM
dwapenyi's Avatar
You may have answered your own question. If GXEs had the fixed mount, then it must not be that bad. Nissan wouldnt let an annoying vibration go out to production on some 80,000+ cars.....and over a 5 year lifespan to boot.
DW
Old Jan 23, 2012 | 11:34 AM
cjandura's Avatar
Yes you can swap them out for the non electric ones.Owners do it all the time.and you can get all 4 mounts on amazon/ebay for less the $130 also you can use 1995-2003 mounts someone correct me on the years if im not right please.
Old Jan 23, 2012 | 11:51 AM
NmexMAX's Avatar
dot dot dot ...
Works fine, did it in my 03. And at one point, was going to do the same in my 95. Kevlo911 has a thread on it somewhere.
My plus is just hanging and no SES/CEL for it either.
Old Jan 23, 2012 | 12:09 PM
Quickywd01's Avatar
I was thinking about this and would like to ask if anyone has experience with filling their mounts? Switch to a non-moving mount up front and fill all four on the engine/trans. The car has a supercharger and I want stiffer mounts.
Old Jan 23, 2012 | 12:15 PM
Quickywd01's Avatar
http://forums.maxima.org/3rd-generat...t-removal.html
http://forums.maxima.org/5th-generat...mount-how.html
http://forums.maxima.org/4th-generat...automatic.html
Old Jan 23, 2012 | 02:47 PM
Shift_A32B's Avatar
Been there, done that, no issues. Mine is GLE and got the front GXE mount. No CEL either.
Old Jan 23, 2012 | 04:12 PM
beegeezy's Avatar
Thanks for the input guys. I already knew the mounts were interchangeable...but I wanted some feedback from owners who had gone this route. So, I wasn't worried about a CEL or anything. Mainly I was just concerned about additional vibration over the adjustable mount.
Anything is likely better than my original mounts with 170k on the clock.
Old Jan 23, 2012 | 04:17 PM
beegeezy's Avatar
Once I get the mounts done I have some freshening up to do for the front suspension/steering. Raybestos control arms, Moog endlinks and inner/outer tie rods, and poly sway bar bushings to go with my recently installed Tokico blues. The car will hopefully be much tighter.
Old Jan 25, 2012 | 06:42 PM
Trini Boom's Avatar
You definitely do not want to use the 02-03 mounts. The price is out there since the mounts are liquid filled. When I went to the dealer to get mine and a guy behind me to get his for an 03 max, it was almost $300 just for the rear mount..
Old Jan 25, 2012 | 07:20 PM
beegeezy's Avatar
Yikes! Thanks for the heads up. I think I'm going to try the ones made by Anchor on Rockauto. I'll probably replace all four mounts for the sake of thoroughness.
Old Jan 26, 2012 | 04:17 AM
CMax03's Avatar
Get some used 95-03 M/T, front/rear motor mounts and mod them with ES MM....and call it the day!
Old Apr 18, 2014 | 05:01 AM
maxinout93's Avatar
Did the 95 gle come with the electronic front mount? I need to order one from amazon, but there are 3 transmission types. REFO4V and REFO4A, 5speed. I assume I have the A, and the V is for VLSD transmission. When I click on gle it says wont fit my car for the standard mount??
Never mind I do have a gle with the electronic mount lol just had to pop the hood and look at it.
Old Apr 20, 2014 | 09:52 PM
Max139617's Avatar
On my last max I was also trying to save a few bucks so I ordered the full set from ebay for about $100. All was good for about 2 days and then all 4 of the mounts had failed. They were even worse than the stock 300k mounts that I had just finished replacing.
Nothing sucks more than having to buy another set of quality parts and paying for labor again. Thinking back I shouldv'e just DIY poyfilled the mounts or bought some ES Bushings.
Old Apr 21, 2014 | 02:12 AM
CS_AR's Avatar
After my I30 had the 1st ECU failure (with the previous owner), I unplugged the electric front mount. No CEL codes or other issues. Also, I couldn't detect any vibration issues after unplugging it. I've read where a short in the electric mount can knock out the ECU.
HOKUSMAX
Nov 13, 2017 04:34 AM
schmellyfart
Sep 25, 2015 04:47 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
