how to make rear marker light blink with turn signals PICS inside
ok guy an gals i wanted my rear marker light to blink with my turn signals like i have my front bumper lights wired (link for that is stickied in the how tos)
so since there wasnt a write up for that mod i did it on my own. Here is the write up with pic and a three part video
first i wanted to make this light
Blink with this light
To start this project locate this connector it behind the carpet in the trunk
Cut the black wire with the pink dot on it pictured here
Then locate the turn signal bulb should have a green and black wire to it
Cut or tap the green wire
then tie the black wire with the pink dot going TO the marker light into the green wire
once you do that you are done i suggest using wire taps i didnt have any so i used solder+electrical tape here is the video it three parts
one with the lights on and turn signal on it will alternate between lights
one with lights off and turn signal on they will flash together
one with lights on and no turn signal the just stay lite
heres the video link
http://s532.photobucket.com/albums/e...20127-1341.mp4
oh follow this guide for the other side there the same
Also i know the 95-96 turn signals will be flipped flopped so just look for the turn signal bulb an proceed
heres a night shot showing front marker lights and signal and rear marker lights and signals first one is with lights off second part is lights on
http://s532.photobucket.com/albums/e...20130-2020.mp4
Dennis Twohy
Oct 1, 2015 06:01 PM
Huttig2009
Sep 25, 2015 03:31 PM
