Camshaft Position Sensor Location
Old Feb 2, 2012 | 10:37 AM
Gman8990's Avatar
Hey guys,
I need to replace the camshaft position sensor in my 99 Maxima. I have heard there's only one in our cars and I was hoping someone could post a diagram of the engine bay with it pointed out to me!
Also, I heard that there may be a recall for this part on our Maxima.. Is that true? Thanks for letting me know!
Gman8990
Old Feb 2, 2012 | 12:02 PM
njmaxseltd's Avatar
On the timing cover, just above the belt tensioner.
Old Feb 2, 2012 | 01:02 PM
BigLou55's Avatar
here you go
Old Feb 2, 2012 | 01:15 PM
D I R T Y I 3 0's Avatar
It's a really easy fix, I remember toying with it when I was replacing my thermostat. Btw, are you experiencing hard starting? I might have to do mine too
Old Feb 2, 2012 | 01:32 PM
Gman8990's Avatar
Im having a hard time starting if thats what you mean. But what Im experiencing is the infamous "Will crank all day, but wont start"... But if it ever does start (which is RARE) it doesnt start hard. It runs just like a champ.
Big Lou, thank you so much! That picture is PERFECT
Old Feb 2, 2012 | 01:43 PM
Phromethius's Avatar
could this sensor cause a dead crank? like turning the key and NOTHING happens? then wait a few seconds in the on position and then it starts? I was just wondering. I know it sounds a lot like the solenoid going bad. I have no experience with this sensor though.
Old Feb 2, 2012 | 02:23 PM
DennisMik's Avatar
^^^^ No. It could be the starter (solenoid or motor) or it could be the ignition switch. But it would not be the cam sensor.
Old Feb 2, 2012 | 02:34 PM
Shucks, I am experiencing more of this
Mine sometimes acts like this. I'll look into my sensor too, did yours throw a code?
Old Feb 2, 2012 | 09:02 PM
Gman8990's Avatar
The sensor was exactly my problem. I replaced it with a part from AutoZone for $59.99. Took out one bolt then snapped the old one out. Undid one of those darn clips that can be kinda frustrating, popped the new one into the clip popped it into the hole for the sensor, then put the bolt back in. All of a sudden, I crank it, and it starts like its brand new! Super easy fix for a relatively cheap price. Thanks for all the tips guys!
Old Feb 2, 2012 | 09:06 PM
Thanks for sharing the results, I am going to go try this out. But you never said if it threw a code?
Old Feb 2, 2012 | 09:10 PM
Gman8990's Avatar
Oh yeah, sorry! Mine did throw a code. I dont recall the number of the code, but it threw one. When I took it to AutoZone to get read it read as the number plus "Camshaft Position Sensor"
Old Feb 2, 2012 | 09:25 PM
Ok cool, use don't want to replace mine if it doesn't come up. I just took off the negative battery cable so no codes will come up til I hook it up
Old Feb 4, 2012 | 09:23 AM
worldwiderecognized's Avatar
i have the no crank upon turning the key issue. doesnt do anything. im thinking faulty ignition switch except it only does it sometimes. like... if i take the car out for a half hour. then turn it off for like 10 mins to go in a store. come out. turn the key and nothing happens. let the car sit for an hour till its cold. then it starts up fine.
i dont know if its the ignition switch or a problem with the starter/starter solenoid being too hot or something? im going to try a used ignition swtich for now someone said it could be a faulty circuit inside the switch. i know its not an issue of the key cylinder grabbing the ignition switch because the teeth are fine on it. hmm.
never thought about this CamshaftPS though. my problem is so rare too i mean it happens infrequently
Old Feb 4, 2012 | 05:58 PM
iDuty's Avatar
If a hot engine gives you a no-crank situation, and it works again after cooling down, then I'd suspect something in the engine compartment that is subject to the heat rather than the ignition switch on the steering column inside the cabin. The starter itself is a suspect.
Old Feb 4, 2012 | 06:38 PM
clintb3astwood's Avatar
A dead crankshaft position sensor can cause this
Old Nov 19, 2018 | 09:05 AM
cdoublejj's Avatar
is it not possible for the sensor to fail and not throw a code? i get a crank no start and sometimes a missfire at crank
Old Nov 19, 2018 | 10:27 AM
Sounds like a crankshaft pos sensor issue but can be the starter or ignition switch as well.
Old Jun 18, 2023 | 02:36 PM
Blax max's Avatar
repair manuals for 2009 Maxima?
I've been to virtually every repair shop I can find and there are NO repair manual s for a 5ht gen Maxima 2009-2015.
I am trying to replace my camshaft position censors and can't find them on YouTube or anything. Can anyone help me locate?
jsmith24
Mar 17, 2015 03:49 PM
rhonster
Aug 25, 2011 06:36 PM
99SEmatic
Feb 8, 2006 06:47 AM
mm347
Nov 23, 2005 10:36 AM
