EGRC Solenoid Valve (Noise)
Old Feb 8, 2012 | 12:50 PM
rhonster's Avatar
Does (or could) a faulty EGRC Solenoid Valve contribute or cause a sound after ignition similar to an exhaust leak? ( Issue seems to dissipate after car warms up, also it is winter here so the colder, the more likely to get the leak sound.)
Old Feb 8, 2012 | 09:28 PM
midnight0045's Avatar
no not to my knowledge. the egrc is a little valve switch located just to the right of the Intake Manifold. I use an extra one as my vacuum canister/butterfly toggle switch with my MEVI Intake Manifold and the only sound it makes is a buzzing sound when it recieves an electronic signal from my RPM switch to activate the egrc switch valve.
Old Feb 8, 2012 | 10:05 PM
ShocknAwe's Avatar
I dont think a faulty switch could itself cause a leak no that doesn't seem possible.IIRC the EGr opens up at about 4kRPM's which therefore you wouldnt be hearing a leak at idle, that would be an IACV leak. Then again, if it is faulty and opening up at the wrong time then I suppose it could cause an abnormal leaking noise. A possible cause is also a broken stem from a slipped wrench or the like. When I had a leak before after installing the NWP spacers, the best way I found to locate it is to simply get in there close and have someone rev the engine to insure, in my case, it was the IACV because it only happened at idle where the IACV takes over.
Old Feb 9, 2012 | 06:25 AM
cashoit's Avatar
usually if the solenoid fails it either fails in the open or closed position and will trigger a CEL.
U can test to see if its getting power and if its actuating or not. Replace if necessary.
Hissing??? Thats a vaccum leak or a tear on a air hose
Old Feb 9, 2012 | 10:59 AM
DennisMik's Avatar
The E in EGR valve stands for exhaust. Maybe the tube that tends to clog up has a hole in it.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
tseng1023
Oct 15, 2015 08:30 AM
uttadms31
Sep 30, 2015 05:24 AM
