My Max is smoking!!!
Old Jan 2, 2002 | 01:55 PM
Ginuwin3112
I have a 99 SE with 25000 miles on it...whenever i drive there is a tremendous amount of white smoke that exits the exaust...and the engine seems to vibrate or shake whenever i press the gas...??? Anyone know what the problem might be??? Thanx!!
Old Jan 2, 2002 | 01:57 PM
Sprint's Avatar
does it do it when its warmed up?
if so.. then pull the ECU code.. its running lean.. your knock sensor might be bad..
Old Jan 2, 2002 | 02:01 PM
Ginuwin3112
YES! i drove about 3 miles today and all the cars around me were covered im white smoke...how do you pull the ecu code??
Old Jan 2, 2002 | 02:03 PM
Sprint's Avatar
you have a serious problem my friend..
http://forums.maxima.org/showthread.php?threadid=45274
get back to us ASAP.. have you changed your oil lately?
Old Jan 3, 2002 | 06:43 AM
njmaxseltd's Avatar
BLOWN HEAD GASKET
BLOWN HEAD GASKET - You've got coolant getting into your cyliners. Don't drive the car anymore. If water (coolant) is getting into your oil and you continue to drive it, your going to distroy your engine.
Old Jan 3, 2002 | 06:56 AM
stash905's Avatar
blown head gasket is right. white smoke means steam. don't drive the car until it's fixed.
Old Jan 3, 2002 | 10:02 AM
Ginuwin3112
That's what i thought it was...The guy at the Nissan dealer said that same thing I will have to get that replaced..Thanks for the help!
Old Jan 3, 2002 | 10:05 AM
Sprint's Avatar
since you have a 99.. and you should be under power train warranty 6/60k .. they should do it for free
Old Jan 3, 2002 | 10:16 AM
Ginuwin3112
Only thing..I have a salvage title
Old Jan 3, 2002 | 10:17 AM
Sprint's Avatar
may explain why your motor is blown
Old Jan 3, 2002 | 12:14 PM
NmexMAX's Avatar
dot dot dot ...
that's not good
Old Jan 3, 2002 | 02:44 PM
Stillen_I30's Avatar
you bought the car with teh salvage title on it?
Old Jan 3, 2002 | 04:12 PM
KGBSJU's Avatar
SAlvage titles are a be-otch to do things with dude...get ur car checked out....really checked out...sometimes those cars have things wrong that are unidentifiable..thus unfixable...even tho everything looks all pretty....get the gaskets changed by nissan or whoever.....maybe everything will be cool
Old Jan 3, 2002 | 04:22 PM
1MAX2NV's Avatar
It might be a blown headgasket or even worst
a crack in the head. Either way, the labor will set you back atleast $800. Hope you don't have to buy new top ends. Brand new will set you back aleast $1000. Overheating the engine will really mess stuff up.
Old Jan 3, 2002 | 05:23 PM
maximus75's Avatar
Re: It might be a blown headgasket or even worst
Just drop a 2002 3.5L in it.
Old Jan 3, 2002 | 05:36 PM
Ginuwin3112
yeah..i hope it's just the gasket and not the head..some guy said it was a crack in the block..?how is that possible??
Old Jan 3, 2002 | 06:12 PM
nixima's Avatar
White smoke is an obvious sign for internal coolant leak. It could be blown head gasket or cracked block. Either way could cause internal coolant leak to the chambers, thus the white smoke.
Old Jan 3, 2002 | 06:17 PM
Ginuwin3112
OIC ..Is it possible to drop the 2002 3.5 in our 4th gens???if so how much would it run???
Old Jan 3, 2002 | 06:22 PM
nixima's Avatar
The 3.5L engine most likely will not fit the transmission case.
Old Jan 3, 2002 | 06:32 PM
maximus75's Avatar
Well i guess he'll just have to get the 6 spd too
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
homewrecker
Sep 24, 2015 07:01 PM
