cel code p0466...
Old Feb 26, 2012 | 03:44 PM
97maxPkNY's Avatar
cel code p0466...
when engine is cold, car runs fine.. after it warms up under low speed or stopping for a light.. it stalls.. then cel comes on with a p0466 code.. evap system circuit blah blahblah.. looked at hoses, didnt see any cracks or leakage from evap canister under rear driver side fender.. any suggestions on what it may be before i spend buku cash on this headache??
Old Feb 26, 2012 | 03:51 PM
P0466? I don't recognize that one. You sure that's the right code?
Old Feb 26, 2012 | 03:55 PM
97maxPkNY's Avatar
i meant the p0446.. sorry
Old Feb 26, 2012 | 04:09 PM
tigersharkdude's Avatar
Code: P0446 | Description: Vent Control Valve
Old Feb 26, 2012 | 04:12 PM
0903 Diagnostic Trouble Code 0903 indicates a problem with the Evaporative Emission (EVAP) Canister Vent Control Valve or its associated electric circuit.
This part is used by the Engine Control Module to perform the fuel system leak test. Since it is used only for self-diagnosis your engine will run perfectly well despite the dashboard Malfunction Indicator Lamp.
The EVAP canister and this valve are located under the car, near the rear left tire. You might check to make sure all the electrical connectors in that area are secure.
There's no telling how expensive the repair will be, because no definite diagnosis has been made. Maybe you just have to re-plug a loose connector. Since the EVAP system is part of the emissions control system you might have warranty coverage
Old Feb 26, 2012 | 05:30 PM
97maxPkNY's Avatar
tigersharkdude.. thanks for the info.. other than the harnesses, there is a way i can check this evap control valve?
Old Feb 26, 2012 | 05:33 PM
^^Cant help you there, Ive never had this problem. All of the info. I posted I got from searching
Old Feb 27, 2012 | 07:47 AM
bobflood's Avatar
Had this same code. Couple of things to do. Take the vent control valve off the cannister, clean it, and bench test it to make sure it operates. Also, there is a bracket on the front of the cannister with a couple of bypass valves and several small hoses. On mine, one of the plastic nipples was broken so it lost vacuum, but the hose held it in place so you couldn't see the problem visually. I didn't find it untill I was poking around and acutally saw the hose end move. I ended up gettting the whole assembly and cannister at a Pull-A-Part yard and just changed out the whole bracket with parts. Good luck.
Old Feb 27, 2012 | 09:46 AM
max ride 41's Avatar
GEE,wonders never cease. search you say??? what the hell is that, oooooo you mean when you dont waste other people's time and your lazy a$$ looks for the code via searching???
Old Feb 27, 2012 | 10:10 AM
EDIT: My online sarcasm detector failed.......sorry bout that
Old Feb 27, 2012 | 10:33 AM
o, well, that was aimed at the op that started the thread man, not joo..
Old Feb 27, 2012 | 10:44 AM
cashoit's Avatar
Agree with Maxride (pains me to say lol )
OP,
Gotta do a SEARCH. Sooooooo much info is right at your fingertips
Old Feb 27, 2012 | 10:52 AM
its all good.
Old Feb 27, 2012 | 03:50 PM
97maxPkNY's Avatar
well... i changed the purge valve.. and changed air filter.. since that was done hasnt stalled on me since.. as far as the so called funny guys.. yeah i searched.. and searched and found many possibilities of what could of been wrong.. i would figure since we are all part of the maxima nation, that maybe some body could steer me in the right direction without spending money changing every nut and bolt.. but hey its better than asking how do i change a head unit.. tigershark and bobflood, thanks for the positive input..
Old Feb 28, 2012 | 12:17 AM
FallenOne's Avatar
Rather than skim the whole thread..
Also, you need to check for a vaccum leak.
Once the car warms up the IACV drops the idle down significantly.
A bad/dirty IACV will also drop it down lower to levels of almost 500 rpm.
This is near stall conditions.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
