4k rpm redline w/ popping noises and horrible gas mileage
Old Mar 8, 2012 | 04:08 PM
  #41
Sandman85's Avatar
Ive replaced vss and still have the code.
Old Mar 9, 2012 | 05:14 PM
  #42
Sandman85's Avatar
What are the symptoms of a failing or dead a/t controller? put a maf from a jy seemed to cure the surging and some of the rough idle. Its definetly mor driveable but not much. The car just started making a weird sound from somewhere by the tb egr area. Sounds almosr like a vacuum leak bit zero symptoms of a leak. Gets louder w/ rpm. I still cant rev past 3.5k in any gear and P N
Old Mar 10, 2012 | 11:14 AM
  #43
Sandman85's Avatar
Will a dead 02 cause the ecu to not rev past 4k, no codes just o2 code. Any ideas??
Old Mar 11, 2012 | 07:30 AM
  #44
Sandman85's Avatar
Bump
Old Mar 11, 2012 | 08:28 PM
  #45
Trini Boom's Avatar
Your cluster is defective. Both P0500 and P0600 at the same time means the TCM is not getting reading from VSS and from cluster. Both pass the information to the cluster before it goes to the TCM. Try resoldering connections or swap entire unit.
Old Mar 23, 2012 | 07:14 PM
  #46
Kuhn_man's Avatar
no it should still rev past 4k
shilov
Feb 19, 2024 09:40 PM
JoshG
51
Sep 21, 2015 10:41 PM
Maxxx10
Sep 13, 2015 03:16 PM
