!HELP! Tranny Issue
Old Mar 5, 2012 | 03:31 PM
jayeyeMax's Avatar
!HELP! Tranny Issue
im new to the forums and this is my first maxima.
i have a 95 se 5 speed.
the problem im having is when i put the car in gear and release the clutch pedal i can feel the car shake really bad as if the tranny is going to fall off.
im almost positive its the clutch but dont want to change it if it doesnt need to be done. can anybody help me?
the car drives fine in everyother gear but 1st and reverse. its only when the clutch is engaged. any help would be greatly appreciated.
Old Mar 5, 2012 | 04:11 PM
maxed_out_99's Avatar
sounds like a warped flywheel to me
either way the trans has to be removed
Old Mar 5, 2012 | 04:23 PM
beegeezy's Avatar
It may be a defective clutch disc or pressure plate too. But like you said, the transmission will have to be pulled to diagnose it any further.
Old Mar 5, 2012 | 07:45 PM
asand1's Avatar
Clutch is chattering from hot (hardened) spots in the flywheel/pressure plate. Replace the clutch assembly and resurface flwheel. Some flywheels get bad enough the hardened spots cant be cleanly cut by the machine shop.
Old Mar 7, 2012 | 05:51 PM
JtzMax's Avatar
Whatchyou say?
Could also be that the clutch is not fully engaging, check the movement of the fork while someone else pushes the clutch, make sure it's traveling as it should.
Old Mar 8, 2012 | 01:51 PM
jayeyeMax's Avatar
thanks for the responses guys, i knew joining this forum was a smart move.
well i didnt drive the car for 2days now just drove it today cause it was beautiful out and the chatter seemed to get better, i did alittle more research and realized it was the clutch/flywheel.
the movement on the slave is good but im going to change it anyway,i should be taking the tranny off this weekend by myself lol.
i ordered slave/master exedy stage 1 clutch and im going to resurface my flywheel hopefully thatll do it. i will keep you guys posted
Old Mar 10, 2012 | 09:57 PM
JtzMax's Avatar
Whatchyou say?
The link in my sig might help if you're going to R+R your trans ... I put together a little something, you'll just have to scan over most of it (rebuilding trans) but I talk about the clutch too ... hope it might help. Really not a bad job to R+R our tranys ... can do mine now in about 3 hrs - with beer breaks!
Old Mar 14, 2012 | 11:59 AM
jayeyeMax's Avatar
well still havent gotten to this, now my car wont go into ANY gear even when the car is off. its really hard to move through the gears
Old Mar 14, 2012 | 06:51 PM
dgeesaman's Avatar
Maintenance Monster
Change the clutch and make sure the flywheel gets remachined. Clean both the flywheel and pressure plate thoroughly with brake cleaner before installing the new clutch.
Avoid shuddering the clutch (rev a little higher if need be) for a while to let the new clutch break in.
David
Old Mar 19, 2012 | 02:07 PM
jayeyeMax's Avatar
David
thanks, great advice
HOKUSMAX
Nov 13, 2017 04:34 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
