Overheating ? HELP
Overheating ? HELP
okay so , this pass Friday I noticed the temp gauge was raising to hot , it needed coolant added some everything was fine , no its going up again and there is no coolant in the car??? , i don't smell any leaks or see any?, coolant reservoir is empty , fans are working fine could it be the radiator? , water pump?
I wouldn't jump to bad head gasket right off the bat and I would think you would smell radiator fluid. Look under your oil cap and see if it looks like chocolate milk..that would tell you. Plus your car would run like crap.
WHat I would do is put a cardboard box folded out under your car, fill up the radiator, start the car. Let it run for 30 minutes (ok if to long 20) and shut it off. Leave the car sit and watch and look around to see leaks.
The last leak I had a was a small hose that went to the throttle body so keep looking (YOU CAN DO ITTTT..LOL)
check your oil for milky color. Clear indication of coolant mixing with oil. Not a good thing.
U have to reaaaaaaaally look for the leak. It can be hard to spot. but if u replacing coolant all the time then obviously u have a leak somewhere
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
