HELP 99 MAXIMA
Old Mar 10, 2012 | 03:01 PM
ALANI80's Avatar
HELP 99 MAXIMA
OK I HAVE A 99 MAXIMA, I CHANGED TRANNY FILTER, SPARK PLUGS AND AIR FILTER LAST WEEK. THEN WHILE ON FREE WAY I NOTICED IT HAD ABSOLUTELY NO POWER WHILE TRYING TO PASS SOMEONE. CHECK ENGINE LIGHT CAME ON AND IT WAS P0100, I BOUGHT A NEW MAF SENSOR, BUT CAR STILL HAS NO POWER. SEEMS TO TOP OUT AT 2400 RPMS WITH PEDAL ALL THE WAY TO FLOOR AND NO POWER,, ANY IDEAS WHAT THE PROBLEM IS?
Old Mar 10, 2012 | 03:07 PM
Amerikaner83's Avatar
Still sounds like MAF...
Could be clogged cat as well...did this just happen at once, or was it gradual? Also...when u did tranny filter, what did you do to fluid...change it? How? With what? Specifically...
Is P0100 the code for the maf or something else?
How does the car idle?
Old Mar 10, 2012 | 03:10 PM
Blackwind's Avatar
Where you live man
Old Mar 10, 2012 | 03:20 PM
Originally Posted by Blackwind
Where you live man
PMed
Old Mar 10, 2012 | 05:14 PM
MAXIMA_STYLE's Avatar
Did yoi unplug the battery when you changed the maf?? Is it an oem maf ? New or used?
Old Mar 10, 2012 | 05:42 PM
ALANI80's Avatar
I PUT DEX MERC 3 ATF MAXLIFE . NEW TRANSMISSION FILTER. NEW PLUGS NEW AIR FILTER AND FUEL FILTER. I WAS GOING TO DRIVE OUT OF TOWN SO I DECIDED TO DO IT ALL BEFORE I LEFT. IT IDLES OK SOMETIMES IT SKIPS. BUT I NOTICED TRYING TO PASS PEOPLE IT JUST HAS NO POWER. CHANGED THE MAF AND STILL HAS NO POWER.. I LIVE IN TUCSON ARIZONA
Old Mar 10, 2012 | 05:46 PM
ALANI80's Avatar
I LIVE IN TUCSON
Old Mar 10, 2012 | 05:49 PM
ALANI80's Avatar
AUTOZONE PRINT OUT SAYS P0100 CODE COULD BE VACUUM LEAK , MAF SENSOR, MAP SENSOR
Old Mar 10, 2012 | 05:51 PM
ALANI80's Avatar
MAF SENSOR WAS FROM AUTOZONE.. ITS REMANUFACTURED NISSAN PART.. U CAN SEE WHERE THEY CUT TOP OUT TO RESOLDER THE PINS.THEN IT WAS SEALED BACK UP
Old Mar 10, 2012 | 06:09 PM
njmaxseltd's Avatar
Check the wires to the MAF sensor. Check for corrosion, lose contacts ect.
Turn your caps lock off.
Old Mar 10, 2012 | 06:26 PM
Check youre vac line to map sensor also... try unplugging your battery for 5-10 minutes also
Old Mar 10, 2012 | 06:40 PM
njmaxseltd's Avatar
Old Mar 10, 2012 | 06:50 PM
ShocknAwe's Avatar
Originally Posted by njmaxseltd
lol kick the tires too.
If the code is a vacuum leak then certainly you have one somewhere. Under the TB is an easy one to forget. The low power could be a few things. Can you tell if its running on all 6? I know people who have bought the reman MAF and never had a problem, they seem pretty simple and easy to reman I suppose. If you changed the spark plugs then possibly they could be bad. My mechanic friend bought a box of 100 plugs I think and all but 4 were bad so it can happen. Check your connector clips and make sure everything was put back right. Sometimes a once over can find a stupid mistake
Old Mar 11, 2012 | 08:01 PM
ADROX's Avatar
I never buy stuff from autozone and that's from a mechanics word of mouth. have heard several of them complain about their remanufactured electrical parts being junk. might try to get that one replaced or borrow someones, just make sure to reset the ecu when you do the change. and yeah there are a few vacuum lines you coulda accidently knocked off or just loosened when changing the filters
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
